dvr firmware
Re: dvr firmware
yes the second one works, however i dont get any output from the rs232 port. and it has a completely different bootup process. not like the other dvr
Re: dvr firmware
I understand.
So, what you plan?
So, what you plan?
Re: dvr firmware
You need TTL from motherboard
Re: dvr firmware
these are the available headers on the board. plus the rs232 on the back of unit
Re: dvr firmware
quiksilvr писал(а):these are the available headers on the board. plus the rs232 on the back of unit
if rs232 is present on back of unit, let's connect to him...
Re: dvr firmware
i was connected to it, but got no output.
Re: dvr firmware
NULL modem cable or..?
Re: dvr firmware
yes null modem cable with com port setting 115200,8,n,1
Re: dvr firmware
with the dvr unplugged, if i hold down (setup) & (enter) buttons on front panel, then plug in power, it goes into "firmware upgrade" mode.
- x 007.jpg (44.21 КБ) 6393 просмотра
Re: dvr firmware
it's old school DVR?
