dvr firmware
quiksilvr
dvr firmware
Сообщение quiksilvr » 01 фев 2017, 16:43
i have a firmware file for my backup dvr and im trying to figure out what OS it is running. i would like to extract the boot loader too, however im not sure what to do next. i used binwalk and this is what i got..
ryn0909@GX270:~$ binwalk iDVR1600T5.10.08.67ENCUTCPM.img
DECIMAL HEXADECIMAL DESCRIPTION
53248 0xD000 gzip compressed data, maximum compression, has original file name: "idvr1600t.bin", from Unix, last modified: 2009-05-01 16:12:08
1363408 0x14CDD0 gzip compressed data, maximum compression, has original file name: "zero.bin", from Unix, last modified: 2005-01-25 06:48:01
1363440 0x14CDF0 gzip compressed data, maximum compression, has original file name: "zero.bin", from Unix, last modified: 2005-01-25 06:48:01
1363472 0x14CE10 bzip2 compressed data, block size = 900k
1366968 0x14DBB8 Microsoft executable, portable (PE)
1418988 0x15A6EC XML document, version: "1.0"
1419987 0x15AAD3 Unix path: /schemas.microsoft.com/SMI/2005/WindowsSettings">
1781352 0x1B2E68 Microsoft executable, portable (PE)
1824104 0x1BD568 Zip archive data, at least v2.0 to extract, compressed size: 140994, uncompressed size: 372736, name: ijl15.dll
1965137 0x1DFC51 Zip archive data, at least v2.0 to extract, compressed size: 52983, uncompressed size: 333824, name: LANGUAGE_RAS.xls
2018166 0x1ECB76 Zip archive data, at least v2.0 to extract, compressed size: 337584, uncompressed size: 851968, name: BackupPlayer.exe
2355796 0x23F254 Zip archive data, at least v2.0 to extract, compressed size: 1482, uncompressed size: 3638, name: bplayer.ico
2357319 0x23F847 Zip archive data, at least v2.0 to extract, compressed size: 184825, uncompressed size: 233059, name: bplayer.skn
2542185 0x26CA69 Zip archive data, at least v2.0 to extract, compressed size: 1180, uncompressed size: 1446, name: bplayer_logo.jpg
2543411 0x26CF33 Zip archive data, at least v2.0 to extract, compressed size: 360, uncompressed size: 734, name: config.ini
2544222 0x26D25E End of Zip archive
2544244 0x26D274 gzip compressed data, maximum compression, has original file name: "idvr400tqc.bin", from Unix, last modified: 2009-05-01 16:12:08
2883476 0x2BFF94 bzip2 compressed data, block size = 900k
2893648 0x2C2750 bzip2 compressed data, block size = 900k
2962908 0x2D35DC bzip2 compressed data, block size = 900k
ryn0909@GX270:~$
Re: dvr firmware
Сообщение iTuneDVR » 01 фев 2017, 20:53
binwalk - it's just little test. You need more deeper research.
Send your firmware to the e-mail.
quiksilvr
Re: dvr firmware
Сообщение quiksilvr » 01 фев 2017, 21:17
ok i sent it
Re: dvr firmware
Сообщение iTuneDVR » 01 фев 2017, 21:22
quiksilvr писал(а):ok i sent it
Got it!
Re: dvr firmware
Сообщение iTuneDVR » 01 фев 2017, 21:40
What it the original device?
Link?
quiksilvr
Re: dvr firmware
Сообщение quiksilvr » 02 фев 2017, 02:20
AVR-1612.pdf
(80.1 КБ) 362 скачивания
this is made by itx-security it is similar to my main dvr unit (the one i bricked) this unit is older version of my main unit
Re: dvr firmware
Сообщение iTuneDVR » 02 фев 2017, 02:40
Last time i'm open another firmware file and extract from them kernel and boot from them - if you remember!
Last time i ask another firmware file because in prev i't not complete image, sime file was missing because they not changed.
This file is interesting.
I think boot, PTZ scheme, and i see windows executable file(player).
Very strange combination!!!
quiksilvr
Re: dvr firmware
Сообщение quiksilvr » 02 фев 2017, 03:03
this unit uses different firmware file than the other unit
Re: dvr firmware
Сообщение iTuneDVR » 02 фев 2017, 03:20
You'r 2'nd DVR is work?
Possible connect to TTL?
Maybe possible tftp dump from then?
quiksilvr
Re: dvr firmware
Сообщение quiksilvr » 02 фев 2017, 04:31
yes it works now, but i cant get any output from the rs232 port
