Чисто китайские 2032F-i, 2020F-i, 2135F-is
CasperZ
Re: Чисто китайские 2032F-i, 2020F-i, 2135F-is
Сообщение CasperZ » 12 янв 2017, 00:50
5.3.0 какой именно? дата
CasperZ
Сообщение CasperZ » 12 янв 2017, 00:57
залил эту V5.3.0 build 150513 отсюда http://hikvision.msk.ru/download/Firmwa ... .05.21.zip
[2017-01-11 23:51:20] TFTP server [192.0.0.128] initialized
[2017-01-11 23:51:27] Device[192.0.0.64]test tftpserver
[2017-01-11 23:51:37] Connect client success [192.0.0.64]Success
[2017-01-11 23:51:37] Start file transmitting[C:\digicap.dav]
[2017-01-11 23:52:18] Completed file[C:\digicap.dav] transmit
[2017-01-11 23:52:44] Device[192.0.0.64]system update completed!
U-Boot 1.3.4-121219 (Apr 8 2015 - 14:34:29)
ARM Clock: 480MHz
DDR Clock: 336MHz
[ INFO][MIN]FORMAT: Formatting Flash
[ INFO][MIN]FORMAT: .....................................
[ INFO][MIN]FORMAT: Format Flash [OK]
[ INFO][MIN]TFTP: TFTP from server 192.0.0.128
[ INFO][MIN]TFTP: Filename: 'digicap.dav'
[ INFO][MIN]TFTP: ################################################################################
[ INFO][MIN]TFTP: Download File [OK]
[ INFO][MIN]BURN: File size is 21615143 bytes (21108 KB)
[UPG][DEBUG_NOTICE][ext/sys_firm_version.c][firm_version_check][435]:i=1,szFileName=_cfgUpgClass,iFirmOffset=0xf14
[UPG][DEBUG_NOTICE][ext/sys_firm_version.c][firm_version_check][479]:####### iFirmVers=0x5030000, sys firm version check ok #######
[UPG][DEBUG_NOTICE][ext/sys_firm_version.c][firm_version_upgrade][626]:####### iFirmVers=0x5030000,iDevsVers=0x5030000,iBase=0x0,iMask=0xffff0000 #######
[ INFO][MIN]BURN: Writing Flash
[ INFO][MIN]BURN: ..........................................................
[ INFO][MIN]BURN: Write Flash [OK]
***** UPDATE COMPLETE *****
после ребута
ARM Clock: 480MHz
DDR Clock: 336MHz
|RCV UDP pack timeout|
Unknown command:null
booting from pri part...
load kernel...
load ramdisk...
init started: BusyBox v1.19.3 (2015-03-20 17:37:48 CST)
starting pid 378, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
UBI device number 1, total 192 LEBs (24772608 bytes, 23.6 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi1_0.
pri_iUpgSuccCnt:0x1, sec_iUpgSuccCnt:0x1
UBI device number 3, total 32 LEBs (4128768 bytes, 3.9 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 31 LEBs (3999744 bytes, 3.8 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
route: ioctl 0x890c failed: No such process
mount: mounting none on /proc/bus/usb failed: No such file or directory
/dav
map_size = 0x300000
nr_item = 3
addr_offset = 0x0 filename = orccode.bin
addr_offset = 0x200000 filename = orcme.bin
addr_offset = 0x2a0000 filename = default_binary.bin
mmap returns 0x40363000
loading ./orccode.bin...addr = 0x40363000, size = 0x19f02d
loading ./orcme.bin...addr = 0x40563000, size = 0x36374
loading ./default_binary.bin...addr = 0x40603000, size = 0x40000
u_code version = 2013/10/24 3.0
ln: /dev/rtc: File exists
=====check_config start=====
===db file doesn't exist===
==== both config files are broken====
netprocess version: 1.4.0 [20:10:19-Mar 10 2015].
pppoed==>pppoed ret -1.
No need to recover kernel pri partition.
No need to recover ramdisk pri partition.
[01-12 13:08:55][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:08:55][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:08:55][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:08:55][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
infd read End
Unix bus 0 .
[01-12 13:08:56][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:08:56][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:08:56][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:08:56][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:08:57][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:08:57][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:08:57][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:08:57][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:08:58][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:08:58][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:08:58][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:08:58][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
IEfile uncompressed.
[01-12 13:08:59][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:08:59][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:08:59][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:08:59][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:09:00][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:09:00][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:09:00][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:09:00][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:09:01][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:09:01][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:09:01][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:09:01][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:09:02][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:09:02][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:09:02][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:09:02][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:09:03][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:09:03][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:09:03][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:09:03][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:09:04][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:09:04][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:09:04][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:09:04][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-12 13:09:05][pid:835][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[01-12 13:09:05][pid:835][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-12 13:09:05][pid:835][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-12 13:09:05][pid:831][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
Unix bus End
[01-12 13:09:06][pid:852][CAPA][ERROR]resolution_num_temp = 0
insmod: can't insert 'uart232.ko': File exists
[01-12 13:09:06][pid:852][OTHER][ERROR]db /davinci/ipc_db does not exist
[01-12 13:09:06][pid:852][OTHER][ERROR]db /config/ipc_db_backup does not exist
powerLineFrequencyMode = 0
[01-12 13:09:06][pid:852][UNI_IF][ERROR]unsupport command = 66
@@@motion PAL!!!!!!!!!!!!!!!!!
[01-12 13:09:06][pid:852][UNI_IF][ERROR]stream request out range 3(2)
sqlite3_get_table:1, no such table: db_version
sqlite3_get_table:1, no such table: sec_lock_auth_db_info
[01-12 13:09:06][pid:852][OTHER][ERROR]db_query_open_v2 error: 1
sqlite3_get_table:1, no such table: netconfig_table
sqlite3_get_table:1, no such table: wep_encrypt_info
[01-12 13:09:06][pid:852][OTHER][ERROR] db_query_open_v2 err
sqlite3_get_table:1, no such table: wep_key_list
sqlite3_get_table:1, no such table: ipaddr_list
sqlite3_get_table:1, no such table: local_port_list
sqlite3_get_table:1, no such table: pppoe_config_info
davinci receive cmd_query_davinci_param.
S: cmd_query_davinci_param
starting pid 863, tty '': '-/bin/sh'
BusyBox v1.19.3 (2015-03-20 17:37:48 CST) built-in shell (ash)
BusyBox v1.2.1 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
# davinci receive cmd_query_davinci_param.
===maxEnchan: 1
[01-12 13:09:10][pid:852][OTHER][ERROR]send flash_log_msg failed, ret = -1
[01-12 13:09:10][pid:852][OTHER][ERROR]can not open file /config/ipc_db_backup
[01-12 13:09:10][pid:852][OTHER][ERROR]ipc_db_backup need backup.
<init_run>3369:p_devcfg->ccdPara[1].capture_mode [0]
<MEGA_DSP>Platform Value:
<MEGA_DSP>Main mux type [0x4].
<MEGA_DSP>Sub mux type [0x4].
<MEGA_DSP>Thi mux type [0x2].
<MEGA_DSP>audio enc type[0x2].
<MEGA_DSP>voicetalk type[0x2].
<MEGA_DSP>Need PS SysHdr[0].
[01-12 13:09:10][pid:852][HW_IF][ERROR]<INIT485>:x=9,maxBaudIdx=15,/dev/uart1
[01-12 13:09:10][pid:852][HW_IF][ERROR]<INIT485>set...baudrate=9600,data=3,stop=0,parity=0,flowcontrol=0
<DSP> DBG:init_dsp_lib() begin
<DSP> DBG:init_dsp_lib() end
[01-12 13:09:16][pid:852][DSP][ERROR][2]g_pdsp->audioTBShare.frameLen=80, g_pdsp->audioTBShare.totalFrame=128..
[01-12 13:09:16][pid:852][SYSINIT][ERROR]max_fps=0...
mknod: /dev/snd/controlC0: File exists
mknod: /dev/snd/pcmC0D0c: File exists
mknod: /dev/snd/pcmC0D0p: File exists
dsp_init: Unsupported viType=0
[01-12 13:09:26][pid:852][SYSINIT][ERROR]hwif_dsp_init error force sys reboot,ret=-12!!!!
ARM Clock: 480MHz
DDR Clock: 336MHz
Hit Ctrl+u to stop autoboot: 1
CasperZ
Сообщение CasperZ » 12 янв 2017, 01:26
еще есть подозрение что я ее пальнул! пока возился с ней, трансфокатор не щелкает и фотодиод не реагирует на свет!
upd не сегодня а еще летом
Сообщение iTuneDVR » 12 янв 2017, 02:44
CasperZ писал(а):[01-12 13:09:26][pid:852][SYSINIT][ERROR]hwif_dsp_init error force sys reboot,ret=-12!!!!
По скольку изменений нет в подключенном виде и ошибка та же сама, а такого быть не должно, значит надо изучать физику процесса.
Сдать девайс в надежные руки мастера.
Локализация?
Камера запитана через POE?
Что на счёт запитки через 12V?
CasperZ
Сообщение CasperZ » 12 янв 2017, 02:46
согласен кому куда? "Сдать девайс в надежные руки мастера."
что значит? "Локализация?"
Сообщение iTuneDVR » 12 янв 2017, 02:51
CasperZ писал(а):согласен кому куда? "Сдать девайс в надежные руки мастера."
Где камера находится.
CasperZ
Сообщение CasperZ » 12 янв 2017, 02:52
Белгород
Сообщение iTuneDVR » 12 янв 2017, 03:05
CasperZ писал(а):Белгород
Конечно, проще на месте, однако ....
Если готовы выслать для исследования, то возможно мастера найдутся.
А почему не сразу вопрос поднялся? Чего ждали?
CasperZ
Сообщение CasperZ » 12 янв 2017, 03:11
я пробовал заняться этим вопросом, даже тему открывал на hik.msk но безуспешно, то времени не было то желания, теперь готов как никогда :) ;) я сделал все что в моих силах и ваших! Спасибо! Отправить готов, по РФ ведь не проблема! кому куда и цена ремонта при условии что на алике 4300р.
Сообщение iTuneDVR » 12 янв 2017, 13:39
CasperZ писал(а):я пробовал заняться этим вопросом, даже тему открывал на hik.msk но безуспешно, то времени не было то желания, теперь готов как никогда :) ;) я сделал все что в моих силах и ваших! Спасибо! Отправить готов, по РФ ведь не проблема! кому куда и цена ремонта при условии что на алике 4300р.
А причем здесь цена товара?
