Problem connect Dahua IPC-HFW4431D
avoida
Сообщение avoida » 17 май 2016, 21:44
I bought Dahua IPC-HFW4431D http://www.aliexpress.com/item/Dahua-H2-65-4MP-IPC-HFW4431D-IR-HD-network-IP-camera-CCTV-EXIR-Bullet-web-camera/32579866493.html?src=ibdm_d03p0558e02r02&aff_platform=aaf&sk=VnYZvQVf%3A&cpt=1463506363293&afref=http%3A%2F%2Fwww.trackitonline.ru%2Faway.php&af=198988&cv=47843&dp=4ee6b355bf31509c0e6bfe32c246b016&&aff_trace_key=588cb9e555814c1f9a31bb4c1e20eeb6-1463506363294-07113-VnYZvQVf
Trying connecting the camera to NVR Hikvision series 7616 but without success - Onvif protocol port 80 with different resolutions 4mp,3mp,2mp
I tried different methods and commands via rtsp 554, also without success.
Does anyone know how I wanted to run this miracle of this NVR.
Is there any feature in the camera settings Dahua, so far I've only worked with Hikvision
avoida
Re: Problem connect Dahua IPC-HFW4431D
Сообщение avoida » 18 май 2016, 14:19
Does anyone know the correct url via rtsp 554 port.
Сообщение iTuneDVR » 18 май 2016, 14:32
avoida писал(а):Trying connecting the camera to NVR Hikvision series 7616 but without success - Onvif protocol port 80 with different resolutions 4mp,3mp,2mp
7616 firmware version?
In witch mode IPC work: H265 or H264?
avoida писал(а):I tried different methods and commands via rtsp 554, also without success.
Witch command. Show it![/quote]
avoida писал(а):Does anyone know how I wanted to run this miracle of this NVR.
Possible you need to use custom mode in you NVR!!!
But first NVR virmware version!
Make screenshot from Onvif Device Manager (ODM) from your Dahua IPC
avoida
Сообщение avoida » 18 май 2016, 17:39
I use H264 coding.
Add photo NVR and IPC Dahua from Onvif DM
Сообщение iTuneDVR » 18 май 2016, 17:55
Screenshots quaity is bad!!!
Firmware NVR too old!!!
ONVIF version from IPC is unreadeable!!!
avoida
Сообщение avoida » 18 май 2016, 22:40
Picture with good quality.
Сообщение iTuneDVR » 18 май 2016, 23:56
Catch Live video on ODM and bottom of window with video & see RTSP string!
Try uprgade NVR firmware!
avoida
Сообщение avoida » 19 май 2016, 08:42
Why in ODM in Live preview no have picture on Onvif format, picture showing just in MJPEG format./MJPEG is bad /?
Сообщение iTuneDVR » 19 май 2016, 12:32
Make a screenshot from this!. Version of ODM?
You try to upgrade NVR???
avoida
Сообщение avoida » 19 май 2016, 19:08
if it has updated the firmware of NVR that will become only Chinese language NVR?
where to download the correct firmware?
Onvif device manager is version 2.2.250
