ZetPro ZIP-3612ER3-PF28-C нужен дамп
dsone
Сообщение dsone » 05 апр 2023, 00:26
Доброго времени суток. В попытках сбросить пароль стер нанд, поспешил и забыл записать загрузчик
U-Boot 2010.06-svn (Dec 12 2019 - 20:14:57)
SPI Nand(cs 0) ID: 0xc8 0xd1 Name:"5F1GQ4UBYIG"
Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4bit/512
ECC provided by Flash Memory Controller
SPI Nand total size: 128MB
MMC:
EMMC/MMC/SD controller initialization.
Card did not respond to voltage select!
No EMMC/MMC/SD device found !
Detected MACID:e4:f1:4c:22:09:36
Press Ctrl+B to abort autoboot in 2 seconds
    uboot # nand erase
    NAND erase: device 0 whole chip
    Skipping bad block at-- 99% complete.
    0x07fe0000
    uboot # update all
    Hisilicon ETH net controler
    phyaddr=[3]
    MAC: E4-F1-4C-22-09-36
    eth0 : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M
    eth0 : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M
    TFTP from server 192.168.0.10; our IP address is 192.168.0.13
    Download Filename 'uimage.bin'.
    Downloading: T #################################################
    done
    Bytes transferred = 7806065 (771c71 hex)
    NAND erase: device 0 offset 0x100000, size 0x900000
    Erasing at 0x9e0000 -- 100% complete.
    NAND write: device 0 offset 0x100000, size 0x900000
    pucRdbuf=0x883acbb0
    pure data length is 9437184, len_incl_bad is 9437184
    ........................................................................ 9437184 bytes written: OK
    phyaddr=[3]
    Download Filename 'program.bin'.
    done
    Bytes transferred = 41025536 (2720000 hex)
    NAND erase: device 0 offset 0xa00000, size 0x5a00000
    Erasing at 0x63e0000 -- 100% complete.
    NAND write: device 0 offset 0xa00000, size 0x5a00000
    pucRdbuf=0x883acbb0
    pure data length is 94371840, len_incl_bad is 94371840
    ................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................ 94371840 bytes written: OK
    uboot # reset
    resetting ...
После данной процедуры в терминале тишина))
Может у кого имеется дамп?
или прошить на прогере u-boot.bin из прошивки?
dsone
Re: ZetPro ZIP-3612ER3-PF28-C нужен дамп
Сообщение dsone » 05 апр 2023, 10:38
[ 1.524272] 0x000000000000-0x000000100000 : "boot"
[ 1.531562] 0x000000100000-0x000000a00000 : "kernel"
[ 1.545026] 0x000000a00000-0x000005400000 : "program"
[ 1.607351] 0x000005400000-0x000006400000 : "cfgbak"
[ 1.626064] 0x000006400000-0x000006500000 : "cliinfo"
[ 1.633454] 0x000006500000-0x000006600000 : "clibak"
[ 1.640843] 0x000006600000-0x000006700000 : "mtd_runtime"
[ 1.648626] 0x000006700000-0x000007700000 : "config"
[ 1.667253] 0x000007700000-0x000007f00000 : "calibration"
[ 1.680312] 0x000007f00000-0x000007f80000 : "update"
[ 1.687371] 0x000007f80000-0x000008000000 : "other"
Я так понимаю мне нужно было очистить область 0x000006700000-0x000007700000
но что-то пошло не так, пока я подбирал нужные команды, набрал nand erase не указав начало и длину.
кирпича я мог избежать если прошил тут же u-boot, но я сделал reset. На что мне сказали - Давай досвидания!
dsone
Сообщение dsone » 05 апр 2023, 22:03
Считал дамп через RT809h. Содержимое прилагаю.
GD5F1GQ4UB@WSON8.rar
(35.53 МБ) 242 скачивания
А также прилагаю прошивку от аналогичной камеры Uniview
GIPC-B6103.16.40.220623.zip
(48.28 МБ) 254 скачивания
Помогите скрестить\. если не сложно
Сообщение iTuneDVR » 14 апр 2023, 23:59
Погляжу.
Не сразу увидел в непрочитанных.
Из прошивки не сделать так т.к. дамп со служебкой и надо искать варианты дампа с другой сходной камеры и менять этот блок.
Погляжу в архиве что есть.
Вернуться в «Видеокамеры IPC»
