...аппарат висит на "матраце"...дамп в почте
help[/b]
hisilicon # help
? - alias for 'help'
base - print or set address offset
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
fatls - list files in a directory (default /)
fload - fload - load binary file from a filesystem image for system boot
flwrite - SPI flash sub-system
go - start application at address 'addr'
help - print command description/usage
lip - lip - set local ip address but not save to flash
lload - lload - load logo file
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mtest - simple RAM read/write test
mw - memory write (fill)
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
reset - Perform RESET of the CPU
run - run commands in an environment variable
setenv - set environment variables
sf - SPI flash sub-system
sip - sip - set server ip address but not save to flash
squashfsload- fsload - load binary file from a filesystem image
tftp - tftp - download or upload image via network using TFTP protocol
usb - USB sub-system
usbboot - boot from USB device
hisilicon #
printenv
hisilicon # printenv
bootcmd=lload;fload;bootm 0x82000000
bootdelay=1
da=mw.b 0x82000000 ff 1000000;tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=mw.b 0x82000000 ff 1000000;tftp 0x82000000 update.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
dd=mw.b 0x82000000 ff 1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
netmask=255.255.0.0
gatewayip=192.168.0.1
ethaddr=00:0b:3f:00:00:01
bootargs=mem=120M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=cramfs mtdparts=hi_sfc:512K(boot),4M
(romfs),5632K(user),1536K(web),3M(custom),256K(logo),1280K(mtd)
ipaddr=192.168.0.110
serverip=192.168.0.102
ver=U-Boot 2010.06-svn104 (Sep 07 2013 - 16:29:50)
Environment size: 1197/262140 bytes
hisilicon #
Falcon Eye FE-0216DE нужна прошивка
Re: Falcon Eye FE-0216DE нужна прошивка
Матрац - беЗспорно у XM.
Интересно.
Видимо тот кто, портит прошивки, совершенствует саму эту тему, потому как картина меняется, чтобы усложнить во многих ситуациях само восстановление.
Вообщем всё в дампе об это явно указано.
Только наличие матраца по сути дампа тоже очевидно, потому, что дальше грузить нечего.
Чем блещет Falcon?
Интересно.
Чем блещет Falcon?
если имеется ввиду техподдержка, то ничем не блещет, т.к. еще не обращался...все равно в выходные никто не ответит.
Возможно прямой вопрос прошивки, даст прямой ответ и решение вопроса.
А дальше уже как было и не раз, по модульно
терзают смутные сомнения по поводу прошивки по-модульно: у них прошивки если XM то с расширением *.fwi...при распаковке модули не обнаруживаются (или знаний не достаточно)
fobos писал(а):терзают смутные сомнения по поводу прошивки по-модульно: у них прошивки если XM то с расширением *.fwi...при распаковке модули не обнаруживаются (или знаний не достаточно)
это не про XM
жду понедельника
Судя по характеристикам, приведенным у них на сайте, можно найти сходный на дивитеке или поливижене и ....
А так, да, понедельник
iTuneDVR писал(а):Судя по характеристикам, приведенным у них на сайте, можно найти сходный на дивитеке или поливижене и ....
можно конечно попробовать, не пропадать же выходным
