Cброс пароля hcvr5108h-s2
dsbios
Сообщение dsbios » 30 май 2016, 14:50
доброго времени суток
имеется регистратор dh-hcvr5108h-s2
нужно сбросить пароль
при подключении через ttl выдает вот это
0Uncompressing Linux... done, booting the kernel.
start to copy FC7500 core boot image...
done, FA6 core now is booting.
ARM eCos   13:48:21
Dec 18 2014
[GM8210] eCos version: 2014_1218_1116, minor version: 1218_1116
<ECOS> Dump Heap 1 Memory information (malloc):
<ECOS> total size of entire pool = 7167512
<ECOS> number of chunks free for use = 1
<ECOS> total allocated space in bytes = 528
<ECOS> total space in bytes not in use = 7166964
<ECOS> size of largest unused block = 7166964
<ECOS> log buffer address: 0x12a400, size: 524288
ECOS: Wait Host core to provide the mbox .Booting Linux on physical CPU 0
Linux version 3.3.0 SVN:5457 (jenkins@Centos-113) (gcc version 4.4.0 20100318 (experimental) (Buildroot 2012.02) ) #1 PREEMPT Wed Jul 8 16:48:12 CST 2015
CPU: FA6 [66056262] revision 2 (ARMv5TE), cr=0000397f
CPU VIPT aliasing data cache, unknown instruction cache
Machine: Grain-Media GM8210
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 195072
Kernel command line: initrd=0x3f600000,0x300000 ramdisk_size=10240 root=/dev/ram rw init=/init mem=256M@0x10000000 gmmem=190M console=ttyS0,115200 mem=512M@0x20000000
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 768MB = 768MB total
Memory: 770964k/770964k available, 15468k reserved, 0K highmem
    vmalloc : 0xb0800000 - 0xff000000   (1256 MB)
    lowmem  : 0x80000000 - 0xb0000000   ( 768 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x804b831c   (4801 kB)
      .init : 0x804b9000 - 0x804db000   ( 136 kB)
      .data : 0x804dc000 - 0x80500560   ( 146 kB)
       .bss : 0x80500584 - 0x80548618   ( 289 kB)
NR_IRQS:128
Timer use APB0 clock
gm_jiffies_init, system HZ: 100, pClk: 49500000
console [ttyS0] enabled
Calibrating delay loop... 789.70 BogoMIPS (lpj=3948544)
Setting up static identity map for 0x1037cfc8 - 0x1037d034
devtmpfs: initialized
FMEM: 48640 pages(0xbe00000 bytes) from bank0 are reserved for Frammap.
FMEM: 126976 pages(0x1f000000 bytes) from bank1 are reserved for Frammap.
FMEM: Logical memory ends up at 0xb0000000, init_mm:0x80004000(0x10004000), PAGE_OFFSET:0x80000000(phys:0x10000000),
Fmem hooks external data-abort handler.
PMU: Mapped at 0xfe000000
IC: GM8210, version: 0x11
PCIE PMU: Mapped at 0xfe00a000
IC: GM8312(1)
iotable: VA: 0xfe000000, PA: 0x99000000, Length: 4096
iotable: VA: 0xfe001000, PA: 0x98300000, Length: 4096
iotable: VA: 0xfe002000, PA: 0x98400000, Length: 4096
iotable: VA: 0xfe003000, PA: 0x98500000, Length: 4096
iotable: VA: 0xfe004000, PA: 0x98800000, Length: 4096
iotable: VA: 0xfe005000, PA: 0x98900000, Length: 4096
iotable: VA: 0xfe006000, PA: 0x82600000, Length: 4096
iotable: VA: 0xfe007000, PA: 0x99100000, Length: 4096
iotable: VA: 0xfe008000, PA: 0x98d00000, Length: 4096
iotable: VA: 0xfe009000, PA: 0x96000000, Length: 4096
iotable: VA: 0xfe00a000, PA: 0xc2700000, Length: 4096
iotable: VA: 0xfe00b000, PA: 0xc2800000, Length: 4096
8210 PCIE: 0xb0808000(0x99e00000), 8312 PCIE: 0xb080a000(0xc3700000)
Switching to clocksource fttmr010:1
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
UDP hash table entries: 512 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 3072K
Video Timer(timer3) Max 86000ms in 0xfdbcaa40 HZ.
msgmni has been set to 1511
gpiochip_add: registered GPIOs 0 to 31 on device: ftgpio010.0
probe ftgpio010.0 OK, at 0xb107c000
gpiochip_add: registered GPIOs 32 to 63 on device: ftgpio010.1
probe ftgpio010.1 OK, at 0xb107e000
Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0xfe002000 (irq = 10) is a 16550A
FTSATA100_AHCI driver version 0.15
bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
nice use GMAC0
ftgmac100: Loading version 0.1 ...
usbcore: registered new interface driver cdc_ncm
i2c /dev entries driver
ftiic010 ftiic010.0: irq 18, mapped at b1082000
usbhid: USB HID core driver
TCP cubic registered
Mobile IPv6
RAMDISK: lzma image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Freeing init memory: 136K
mount: mounting none on /dev/pts failed: No such file or directory
mdev: applet not found
mount: mounting tmpfs on /dev/shm failed: No such file or directory
[RCS]: /etc/init.d/S00devs
mknod: /dev/console: File exists
mkdir: can't create directory '/dev/input': File exists
mknod: /dev/input/mice: File exists
[RCS]: /etc/init.d/S01udev
/etc/init.d/S01udev: line 7: /sbin/mdev: not found
[RCS]: /etc/init.d/S81toe
[RCS]: /etc/init.d/S99dahua
Mounting root fs rw ...
Mounting other filesystems ...
Setting hostname ...
/etc/init.d/S99dahua: line 16: hostname: not found
 ############## frammap.ko svn 25035 Jul  8 2015 18:29:47
Frammap: DDR0: memory base=0x14000000, memory size=0xbe00000, align_size = 4K.
Frammap: DDR1: memory base=0x20000000, memory size=0x1f000000, align_size = 4K.
Frammap: version 1.1.2, and the system has 2 DDR.
Frammap: fail to open /mnt/mtd/config_8210, /tmp/template_8210 is created.
cpucomm svn 25035 Jul  8 2015 18:29:42
ep_cnt = 0, non_ep_cnt = 2
mem_alloc_init: physical memory begins at 0x14000000, ends at 0x15000000, 0x1000000 bytes.
cpucomm: use dmach mask: 0xc0
Wait Host core to provide the mbox .done
--- mbox paddr: 0xd800000, vaddr: 0xb18ae000 ---
Wait FA726 core ready...done
--- ECOS: mbox paddr: 0xd800000, vaddr: 0xd800000 ---
ECOS: Wait FA626 core ready..done
cpucomm: board FA726, PoolMem:(paddr:0xd800000, size:0x800000, vaddr:0xb4000000, cbaddr:0xb5000000). ShareMem:(paddr:0xd801000, size:0x12000, vaddr:0xb4001000)
Wait FC7500 core ready..done
cpucomm: board FC7500, PoolMem:(paddr:0x0, size:0x1000000, vaddr:0xb6000000, cbaddr:0xb8000000). ShareMem:(paddr:0xfde6f0, size:0x12000, vaddr:0xb6fde6f0)
ok, cpu_comm_2.7 driver is executed in FA626 core with dma_type: 1(1).
/etc/init.d/load_mod: line 6: mdev: not found
Bigin recv file from FA726...
End recv file from FA726...
video_system PAL
/mnt/mtd/avss.info
ddr name: frammap0
base: 0x14000000
end: 0x1fe00000
memory allocated: 0x1000000 bytes
memory free: 0xae00000 bytes
max available slice: 0xae00000 bytes
memory allocate count: 1
clear address: 0x15000000
dirty pages: 4096
clear pages: 44544
size alignment: 0x1000
ddr name: frammap1
base: 0x20000000
end: 0x3f000000
memory allocated: 0x0 bytes
memory free: 0x1f000000 bytes
max available slice: 0x1f000000 bytes
memory allocate count: 0
clear address: 0x20000000
dirty pages: 0
clear pages: 126976
get_audio_chl_num:1
get_video_chip:19
get_mic_mux:1
input_res = 15
output_type = 51
get_tv_support:0
log: module license 'GM' taints kernel.
log.ko:svn 25035 Jul  8 2015 18:29:35 (mmap 0x829b0000 size 0xc000)
LOG base 0xb3001000 size 8192K (start pointer 0x7f028ca8)
PAGE_OFFSET(0x80000000) VMALLOC START(0xb0800000) HZ(100)
cpu_type=18 video_chip=19 digital_chn_num=0 video_chn_num=8 speceial_custom 0,audio_chn_num=1 abroad=0 hwid=67109034 iva_support=0 mic_mux=1 tv_support=0 vstd=0 ad_dev_num=2 input_res 0
ms.ko v0.8 svn 25035 Jul  8 2015 18:29:37
ECOS FC7500 for FA626 core, share memory phyaddr: 0x14016000, size: 0x12000, vaddr: 0x14016000
ECOS FC7500 for FA626 core, pool memory phyaddr: 0x14000000, size: 0x1000000, vaddr: 0x14000000
CPU_COMM version: 2.2 in FC7500
ecos_device_open -- FC7500 Record opens a channel for read/write.
ecos_device_open -- FC7500 Playback opens a channel for read/write.
ecos_device_open -- FC7500 Heart beat opens a channel for read/write.
960H capenc Buffer clean enabled
em.ko v0.26 svn 25035 Jul  8 2015 18:29:19
em_user v0.6 Jul  8 2015 18:29:19
EM Module Service Starting (callback_period = 3ms)
Start EM thread 2(em_callback:2) with nice -20
Start EM thread 0(em_callback:0) with nice -20
Start EM thread 1(em_callback:1) with nice -20
LCD platform: Hook GM8210 driver.
[mod0]fb0_num[1],fb1_num[1],fb2_num[1],output_type[51],input_res[15],lcd_disable[0],fb0_fb1_share[0],fb1_pan_display[0],vs_width[0],vs_height[0],bf[0],d1_3frame[0],gui_clone_fps[25]
GM_ffb: [ver:0.1.19]INIT flcd200 OK.
LCD0: PA = 0x9a800000, VA = 0xb1960000, size:0xd000 bytes
LCD0(SLI10121): Output resolution is 1920x1080/60HZ.
LCD0: Input resolution is 1920x1080
LCD0 registers 1 entities to video graph!
LCD0: Driver[Ver: 1.2.2] init ok. fb0_fb1_share:0, fb1_pan_display:0
zebra_device_open -- lcd0_drv opens a channel for read/write.
[mod1]fb0_num[1],fb1_num[1],fb2_num[1],output_type[1],input_res[1],lcd_disable[1],fb0_fb1_share[1],fb1_pan_display[0],vs_width[0],vs_height[0],bf[0],d1_3frame[1],gui_clone_fps[10]
GM_ffb: [ver:0.1.19]INIT flcd200_2 OK.
LCD2: PA = 0x9b800000, VA = 0xb1990000, size:0xd000 bytes
LCD2: Output resolution is D1 PAL.
Register codec TVE100.
LCD2: Input resolution is PAL
LCD2 joins D1 of 3frame.
LCD2: Driver[Ver: 1.2.2] init ok. fb0_fb1_share:1, fb1_pan_display:0
zebra_device_open -- lcd2_drv opens a channel for read/write.
HDMI sli10121 works in PCIe mode, pa = 0xc1900000, va = 0xb195a000.
Register codec sli10121-480P_BT1120.
Register codec sli10121-576P_BT1120.
Register codec sli10121-1024x768_RGB.
Register codec sli10121-1280x1024_RGB.
sli-hdmi is in 1920x1080 RGBLCD210: Input format to sli-hdmi is RGB888.
sli10121_polling_thread INIT = 0
HDMI_init, 1
Register codec sli10121-1920x1080_RGB.
Register codec sli10121-1280x720_RGB.
sli10121 sleep 100 ms
zebra_device_open -- hdmi opens a channel for read/write.
fe_common version 140714
res:15 brightness_value:-5 onoff:0
hdmi_test mode=0
i2c_test=1,dev_num=2,clk_used=0 clk_src=4 clk_freq=27000000 init=1 rstb_used=0 ch_map=0 sample_rate=0 sample_size=1 notify=1 audio_num=1 codec_type=1 hwid=67109034 isDev626=0 video_chip=19 encode_type=0 mic_mux=1 iaddr=60 =62   vout_format=0 =0  vout_mode=0 =0
adda.ko: Version: V0.00.074 Svn: 25035 Compile at Jul  8 2015 18:30:02
video_chip=19
audio_num=1
mic_mux=1
codec_type=1
SLI HDMI_interrupt, MASK_92h = 0xc0, INT_94h = 0x0
adda_sys_channel_maps: hwid=0x40000aa
dh9910_config_vdport: stDH9910VdPortConfig[0].ucVClkConfig = 0xaa
dh9910_config_vdport: stDH9910VdPortConfig[1].ucVClkConfig = 0xaa
dh9910_config_vdport: stDH9910VdPortConfig[2].ucVClkConfig = 0xaa
dh9910_config_vdport: stDH9910VdPortConfig[3].ucVClkConfig = 0xaa
reset 9910!!
dh9910_video_init begin  VD_PORT_MUX_MOD 0
dh9910_video_init ChipId 0 end
audio audio 9910!
dh9910_audio_init: first Stage of cascade
DH9910#0 Init...OK!
dh9910_video_init ChipId 1 end
audio audio 9910!
dh9910_audio_init: second Stage of cascade
DH9910#1 Init...OK!
cap_scl_up_disable =0
[VCAP_INFO]: VCAP300 Version: 0.3.5A svn 25035 Jul  8 2015 18:30:05
vi_mode [1 1 1 1], cap_md=1,grab_filter=0
vport= 0x2341,0x5768,inv_clk =0 0 data_swap 0 0
dhcvi_vport_map: vport[0]=0x4123
dhcvi_vport_map: vport[1]=0x8675
dhcvi_vport_map: vport[2]=0x0
dhcvi_vport_map: vport[3]=0x0
[VCAP_INFO]: Register DH9910#0 Input Device
[VCAP_INFO]: Register DH9910#1 Input Device
max_vch_num=128,max_minors=100,temp_width=1920,temp_height=1080,scal_dmaparm=0
scaler300.ko:version 141017, svn 25035 Jul  8 2015 18:30:14
fscaler300_init_one [0] NCNB
fscaler300_init_one [1] NCNB
scaler_trans_init, version: 0x20140822
scaler_trans_init, Wait RC FA726 provides the directIO memory...
.scaler_trans_init, done, the directIO physical address: 0xe000000
minor_balance=0
FTDI220 registers 64 entities to videograph.
FTDI220 Driver v3.10 (2 engine(s))
MCP100 GM8210, built @ Jul  8 2015 18:30:35
h264e_max_b_frame =0,h264e_max_width =1920,h264e_max_height =1088,h264e_tight_buf =0,dh_extra_D1_buf =0
FAVC Encoder v0.1.116, built @ Jul  8 2015 18:30:25 (GM8210)
H264 rate control version: 1.1.10.1, built @ Jul  8 2015 18:30:28
FAVC Decoder IRQ mode(30, 40) PLT:8210, version 0.2.140.0 built @ Jul  8 2015 18:30:32
GM8210 MJPEG, encoder v4.0.18, decoder v4.0.7, built @ Jul  8 2015 18:30:36
MJPEG rate control version: 0.0.1, built @ Jul  8 2015 18:30:28
ssp_num[0,1,2] ssp_chan[8,1,2] bit_clock[2048000,2048000,512000] sample_rate[8000,8000,8000] audio_out_enable[1,1,1]
audio_init: audio driver is inserted, minor version: 1218_1116
audio_drv.ko:svn 25035 Jul  8 2015 18:30:40
zebra_device_open -- AU_ENTITY opens a channel for read/write.
zebra_device_open -- AU_Heart opens a channel for read/write.
audio_init: eCos and fa626 version(2014_1218_1116) matched, fa626 minor version(1218_1116)
set log buffer address: 0x0012a400, size: 524288
GM_ffb(pip_handle_irq): LCD0: FIFO under-run!
reserved_ch_cnt 32,apply_mode=1,flow_mode=1,dh_sub_yuv_enable=1
gs.ko v1.5 svn 25035 Jul  8 2015 18:29:22
GS driver, log: level(0) category(0) bmp width(64)
Ft2dge uses hclk/2.
Ft2dge driver version: 2.7
idn=36,mem=2720
osg canvas is static allocate mode
SWOSG ver 0.2.9
set canvas static pool fail(ch(7)mem(0))
set canvas static pool fail(ch(11)mem(0))
set canvas static pool fail(ch(15)mem(0))
set canvas static pool fail(ch(19)mem(0))
set canvas static pool fail(ch(23)mem(0))
set canvas static pool fail(ch(27)mem(0))
set canvas static pool fail(ch(31)mem(0))
set canvas static pool fail(ch(35)mem(0))
cpu_chip=18,dh_intelli_dev=0,vpslv_dbglevel=0,ddr0_sz=0,ddr1_sz=0,datain_minors=128,dataout_minors=128
vpd_slave.ko v1.5 svn25035 Jul  8 2015 18:29:28
config_path="/mnt/mtd/"
cpucomm slave init:
    m01: Bus(100)
zebra_device_open -- m01 opens a channel for read/write.
    getcp_m01: Bus(101)
zebra_device_open -- getcp_m01 opens a channel for read/write.
    qbs_m01: Bus(102)
zebra_device_open -- qbs_m01 opens a channel for read/write.
    pk_m01: Bus(103)
zebra_device_open -- pk_m01 opens a channel for read/write.
Parsing CAP vg_info version: 0.3.5
vplib v1.8 Jul  8 2015 18:29:28
config_init v0.18 Jul  8 2015 18:29:29 /mnt/mtd//gmlib.cfg
; GM8210_8HD_720P Product Configuration
[VERSION]
VERSION = 0.1
[GRAPH_TYPE]
; graph type: 1(DVR with display 3DI), 2(IPCAM)
graph_type = 1
[DISPLAY_GROUP]
; GROUP0 = lcd_vch0, lcd_vch1
; Display group method:
;   0(FRAME), 2(2FRAME), 3(2FRAME_2FRAME), 4(FRAME_FRAME)
GROUP0 = 0, 1
METHOD0 = 4
[BITRATE]
min_compressed_ratio = 20
max_bitrate = 1080P/8192K, 720P/6144K, 960H/6144K, D1/4096K, HD1/2048K, 2CIF/2048K, CIF/1024K, QCIF/0256K
[PLAYBACK]
; CONFIG1 = resolution_keywords/channels/total_fps/ddr_channel, ...
; default resolution keywords: 8M, 5M, 4M, 3M, 2M, 1.3M, 1M, nHD, 1080P, 720P, D1, VGA, CIF, QCIF
CONFIG1 = 1080P/8/120/0, QCIF/2/060/0
CONFIG2 = 720P/8/240/0, QCIF/2/060/0
[PLAYBACK_3DI]
[ENCODE_STREAMS]
CONFIG1 = 1080P/8/120/1, D1/8/240/1
CONFIG2 = 720P/8/240/1, D1/8/240/1
[ENCODE_CAPTURE]
CONFIG1 = 1080P/8/120/1, D1/1/030/1
CONFIG2 = 720P/8/240/1, D1/1/030/1
[ENCODE_SCALER]
; CONFIG1 = resolution keywords = channels/total_fps/ddr_channel, ...
CONFIG1 = D1/8/240/1
[ENCODE_DIDN]
[RAW_OUT]
; CONFIG1 = channels/total_fps/ddr_channel, ...
CONFIG1 = QCIF/1/15/1
[LDC_OUT]
[AUDIO]
; CONFIG1 = audio_keyword/channels/sample_rate/stereo/bits/ddr_vch
CONFIG1 = au_grab/16/16K/mono/16/1, au_render/4/16K/mono/16/1
max_frame_samples = 2048
grab_buffer_time = 1172
render_buffer_time = 768
[BUFFER_DISPLAY]
; Display count lcd_vch/count/ddr_channel, lcd_vch/count/ddr_channel, ...
display_count = 0/14/1
ride_disp_scl_in = 2
; Playback 3DI input buffer count per channel
playback_3di_input_count = 0
; Playback scaler input buffer count per channel
playback_scaler_input_count = 3
[BUFFER_BITSTREAM]
; Playback bitstream data buffer: time/ddr_vch
datain_buffer_time = 398/1
; Record bitstream data buffer: time/ddr_vch
dataout_buffer_time = 495/1
[BUFFER_CAPTURE]
; Encode capture buffer three slop: fps/count, fps/count, fps/count
CONFIG1 = 1080P/30/7, 1080P/15/7, 1080P/1/2
CONFIG2 = 1.3M/30/6, 1.3M/15/4, 1.3M/1/2
CONFIG3 = 720P/30/6, 720P/15/4, 720P/1/2
CONFIG4 = 960H/30/6, 960H/15/4, 960H/1/2
CONFIG5 = SVGA/30/6, SVGA/15/4, SVGA/1/2
CONFIG6 = D1/30/6, D1/15/4, D1/1/4
CONFIG7 = 2CIF/30/6, 2CIF/15/4, 2CIF/1/2
CONFIG8 = HD1/30/6, HD1/15/4, HD1/1/2
CONFIG9 = CIF/30/6, CIF/15/4, CIF/1/2
CONFIG10 = QCIF/30/6, QCIF/15/4, QCIF/1/2
capture_max_fps = 30
[BUFFER_ENCODE_DIDN]
; Encode substream scaler out buffer time
encode_didn_out_buffer_count = 0
[BUFFER_SUBSTREAM]
encode_scaler_out_buffer_count = 3
[BUFFER_RAW]
raw_out_buffer_count = 4
[BUFFER_LDC]
ldc_out_buffer_count = 0
[ENCODE_MOTION]
; Enable motion data under specified resolution by "motion_resolution = D1, CIF..."
; motion_resolution = CIF
[SNAPSHOT]
yuv_max_width = 1920
yuv_max_height = 1080
max_bitstream_size = 4147200
[RESERVED_BUFFER]
; Reserved buffer ratio for seamless switching usage, such as 4CH 720P->4CH 1080P without any stop
reserved_ratio = 10
gmlib end
;file name:pgmlib_cfg_8210_8CHNo support encode motion data information
   8M  3840x2160  max_frame: 2488320  average: 100539  motion:      0
   7M  3264x2176  max_frame: 2130739  average:  45909  motion:      0
   6M  3072x2048  max_frame: 1887436  average:   8738  motion:      0
   5M  2592x1952  max_frame: 1517875  average: 231897  motion:      0
   4M  2304x1728  max_frame: 1194393  average: 182476  motion:      0
   3M  2048x1536  max_frame:  943718  average: 144179  motion:      0
1080P  1920x1088  max_frame:  626688  average:  34952  motion:      0
 1.3M  1280x1024  max_frame:  393216  average:  60074  motion:      0
 1.2M  1280x 960  max_frame:  368640  average:  56320  motion:      0
1080I  1920x 544  max_frame:  313344  average:  47872  motion:      0
   1M  1280x 800  max_frame:  307200  average:  46933  motion:      0
 720P  1280x 720  max_frame:  276480  average:  26214  motion:      0
 960H   960x 576  max_frame:  165888  average:  26214  motion:      0
 SVGA   800x 608  max_frame:  145920  average:  22293  motion:      0
 720I  1280x 368  max_frame:  141312  average:  21589  motion:      0
   D1   720x 576  max_frame:  124416  average:  17476  motion:      0
  VGA   640x 480  max_frame:   92160  average:  14080  motion:      0
  nHD   640x 368  max_frame:   70656  average:  10794  motion:      0
 2CIF   368x 608  max_frame:   67123  average:   8738  motion:      0
  HD1   720x 288  max_frame:   62208  average:   8738  motion:      0
  CIF   368x 288  max_frame:   31795  average:   4369  motion:      0
 QCIF   176x 144  max_frame:   20480  average:   2048  motion:      0
  disp0_in DDR1 1920x1080+720x576, method(4)
    (4050KB x 1 + 810KB x 1)  x 14
    ==> 68068KB (ddr1)
  disp_scl_in DDR0 1920x1088 8CH scl_in_decuple(30)
  disp_scl_in DDR0 176x144 2CH scl_in_decuple(30)
    4080KB x 24
    1020KB x 24
    49KB x 6
    12KB x 6
    ==> 122891KB (ddr0)
  dec_in DDR1 1920x1088 8CH fps(120) time(398) aver_sz(34952) max_sz(626688) count(4)
  dec_in DDR1 176x144 2CH fps(48) time(398) aver_sz(2048) max_sz(20480) count(7)
    1842KB x 8 (win=612KB x2 aver=34KB x7)
    72KB x 2 (win=20KB x2 aver=2KB x7)
    ==> 14880KB (ddr1)
  enc_cap_out DDR1 1920x1088 8CH fps(120) factor(100)
           total_fps(120) aver(8CH/15fps/7)
  enc_cap_out DDR1 720x576 1CH fps(24) factor(100)
           total_fps(24) aver(1CH/24fps/5)
    4080KB x 56
    810KB x 5
    ==> 232652KB (ddr1)
  enc_out DDR1 1920x1088 8CH fps(120) time(66) aver_sz(34952) max_sz(626688) count(5)
  enc_out DDR1 720x576 8CH fps(240) time(33) aver_sz(17476) max_sz(124416) count(13)
    1842KB x 8 (win=612KB x2 aver=34KB x13)
    494KB x 8 (win=121KB x2 aver=17KB x13)
    ==> 18694KB (ddr1)
  enc_scl_out DDR1 720x576 8CH fps(240) decuple(30)
    810KB x 24
    ==> 19488KB (ddr1)
  au_grab_out DDR1 16CH 16K tracks(1) bits(16) samples(2048) latency(1172) count(9)
    128KB x 9
    ==> 1170KB (ddr1)
  au_render_in DDR1 4CH 16K tracks(1) bits(16) samples(2048) latency(768) count(6)
    16KB x 6
    ==> 204KB (ddr1)
  Reserved buffer ratio=10
  DDR0 size=122891KB
  DDR1 size=355156KB
#### Capture Count ####
 RES/FPS  1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 40 45 50 55 60
3840x2160 0 0 0 0 0 0 1 1 1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1  1
3264x2176 0 0 0 0 0 0 1 1 1  1  1  1  1  1  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2
3072x2048 0 0 0 0 0 0 1 1 1  1  1  1  1  1  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2
2592x1952 0 0 0 1 1 1 1 1 1  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2  2
2304x1728 1 1 1 1 1 1 2 2 2  2  2  2  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3  3
2048x1536 1 1 1 1 1 1 2 2 2  3  3  3  3  3  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4
1920x1088 2 2 2 3 3 3 4 4 4  5  5  5  6  6  7  7  7  7  7  7  7  7  7  7  7  7  7  7  7  7  7  7  7  7  7
1280x1024 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
1280x 960 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
1920x 544 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
1280x 800 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
1280x 720 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 960x 576 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 800x 608 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
1280x 368 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 720x 576 4 4 4 4 4 4 4 4 4  4  4  4  4  4  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 640x 480 4 4 4 4 4 4 4 4 4  4  4  4  4  4  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 640x 368 4 4 4 4 4 4 4 4 4  4  4  4  4  4  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 368x 608 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 720x 288 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 368x 288 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
 176x 144 2 2 2 2 2 2 2 2 3  3  3  3  3  3  4  4  4  4  4  4  4  4  5  5  5  5  5  5  5  6  7  7  8  9  9
bufferSea_ddr0     122891 KB + 12289 KB(reserved)
                   (cacheable)
bufferSea_ddr1     355156 KB + 23265 KB(reserved)
                   (cacheable)
disp_scl_in 122891 KB (DDR0)
                  DDR0 pool free size 12289KB.
   disp0_in 68068 KB (DDR1)
                  fill disp0_in pattern 0x10801080
                  DDR1 pool free size 310354KB.
  dec_bs_in 14880 KB (DDR1)
                  DDR1 pool free size 295474KB.
enc_cap_out 232652 KB (DDR1)
                  fill enc_cap_out pattern 0x10801080
                  DDR1 pool free size 62822KB.
 enc_bs_out 18694 KB (DDR1)
                  DDR1 pool free size 44127KB.
enc_scl_out 19488 KB (DDR1)
                  DDR1 pool free size 24639KB.
au_grab_out  1170 KB (DDR1)
                  DDR1 pool free size 23469KB.
au_render_in   204 KB (DDR1)
                  DDR1 pool free size 23265KB.
datain v0.2 Jul  8 2015 18:29:29
dataout v0.6 Jul  8 2015 18:29:30
osd_mg_database_init......osd_type:0
osd_mg_database_init......osd_type:1
osd_mg_database_init......osd_type:2
usr_clearwin v0.21_clearbitstream_counting Jul  8 2015 18:29:32
usr_clearwin init fd(0x60000000) idx(0) buffer(0x929fd400/0x229fd400)
usr_clearwin init fd(0x60000000) idx(1) buffer(0x92ebc800/0x22ebc800)
usr_clearwin init fd(0x60000000) idx(2) buffer(0x9337bc00/0x2337bc00)
usr_clearwin init fd(0x60000000) idx(3) buffer(0x9383b000/0x2383b000)
usr_clearwin init fd(0x60000000) idx(4) buffer(0x93cfa400/0x23cfa400)
usr_clearwin init fd(0x60000000) idx(5) buffer(0x941b9800/0x241b9800)
usr_clearwin init fd(0x60000000) idx(6) buffer(0x94678c00/0x24678c00)
usr_clearwin init fd(0x60000000) idx(7) buffer(0x94b38000/0x24b38000)
usr_clearwin init fd(0x60000000) idx(8) buffer(0x94ff7400/0x24ff7400)
usr_clearwin init fd(0x60000000) idx(9) buffer(0x954b6800/0x254b6800)
usr_clearwin init fd(0x60000000) idx(10) buffer(0x95975c00/0x25975c00)
usr_clearwin init fd(0x60000000) idx(11) buffer(0x95e35000/0x25e35000)
usr_clearwin init fd(0x60000000) idx(12) buffer(0x962f4400/0x262f4400)
usr_clearwin init fd(0x60000000) idx(13) buffer(0x967b3800/0x267b3800)
usr_decode v0.1 Jul  8 2015 18:29:32
usr_snapshot v0.18 Jul  8 2015 18:29:32 (1920x1080, 4050KB)
usr_getraw v0.5 Jul  8 2015 18:29:32
usr_cap_source v0.1 Jul  8 2015 18:29:32
usr_osg v1.9 Jul  8 2015 18:29:32
usr_osg: (ch_table) 12 ,0 ,4 ,8 ,28 ,20 ,24 ,16 ,-1 ,-1 ,-1 ,-1 ,-1 ,-1 ,-1 ,-1 ,
vpslv_init: set pool(disp0_in) size (69701632) va(0x929fd000) pa(0x229fd000) pci_addr(0xffffffff)
write engine 0 2Ch temporalEn as 0 (0x00002208)
write engine 1 2Ch temporalEn as 0 (0x00002208)
vpslv set vpslv_dbglevel=0
write engine 0 30h spatialEn as 0 (0x02400022)
write engine 1 30h spatialEn as 0 (0x02400022)
write engine 0 2Ch tdn_var_cr as 2 (0x00002208)
write engine 1 2Ch tdn_var_cr as 2 (0x00002208)
write engine 0 2Ch tdn_var_cb as 2 (0x00002208)
write engine 1 2Ch tdn_var_cb as 2 (0x00002208)
write engine 0 2Ch tdn_var_y as 2 (0x00002202)
write engine 1 2Ch tdn_var_y as 2 (0x00002202)
write engine 0 34h tdi_motion_blk_th as 80 (0x76060950)
write engine 1 34h tdi_motion_blk_th as 80 (0x76060950)
DDR0 setting...
0x07E49E02
0x00421C70
0x00000098
0x52B51525
0x00002060
0x00000008
0x06060606
0x00640013
DDR1 setting...
0x07E49E02
0x00401C70
0x00000098
0x52B51525
0x00002060
0x00000020
0x06060606
0x00640013
scaler setting...
0x01580000
0x01580000
0x00000158
0x00000158
##### Apply #1 #####
Frammap: 2914 pages in DDR0 are freed.
Frammap: 21621 pages in DDR1 are freed.
Set EM debug level(0) (0:quiet 1:get/put 2:property 3:semaphore)
Set GraphService debug level(0). (0 for error, 1 for flow, 2 for detail.)
Set MemoryService debug level(0).
Set datain debug level(0)
Set dataout debug level(0)
../src/cpu_comm_manager.c INFO  (func = main line =>508): ****************************************************************************************
../src/cpu_comm_manager.c INFO  (func = main line =>509): libcpucomm.a: Version: V0.00.013 Svn:24928 APIs(Svn:40608) Compile at Jul  8 2015 18:29:11
../src/cpu_comm_manager.c INFO  (func = main line =>510): ****************************************************************************************
core=-1,channel=0
../src/cpu_comm_manager.c INFO  (func = OpenCpuCommCh line =>404): my is FA6! gFd_chan2: 5
../src/slave_osd.c INFO  (func = showDataOtherExtendOSD_thread line =>332): func showDataOtherExtendOSD_thread ,pid 499
../src/slave_osd.c INFO  (func = showDatatimeExtendOSD_thread line =>382): func showDatatimeExtendOSD_thread ,pid 498
../src/cpu_comm_manager.c INFO  (func = dealOsdCmdThread line =>293): func dealOsdCmdThread ,pid 497
../src/cpu_comm_manager.c INFO  (func = simulateIoctlThread line =>115): func simulateIoctlThread ,pid 496
9901 chip_id:0 chn:0 cvi_ch:0 loss_stats:1
9901 chip_id:0 chn:1 cvi_ch:1 loss_stats:1
9901 chip_id:0 chn:2 cvi_ch:2 loss_stats:1
9901 chip_id:0 chn:3 cvi_ch:3 loss_stats:1
9901 chip_id:1 chn:4 cvi_ch:0 loss_stats:1
9901 chip_id:1 chn:5 cvi_ch:1 loss_stats:1
9901 chip_id:1 chn:6 cvi_ch:2 loss_stats:1
9901 chip_id:1 chn:7 cvi_ch:3 loss_stats:1
##### Apply #2 #####
##### Apply #3 #####
##### Apply #4 #####
##### Apply #5 #####
##### Apply #6 #####
##### Apply #7 #####
##### Apply #8 #####
##### Apply #9 #####
##### Apply #10 #####
[favce]{chn1} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
[favce]{chn2} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
[favce]{chn0} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
[favce]{chn3} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
[favce]{chn5} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
[favce]{chn4} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
[favce]{chn7} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
[favce]{chn6} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
notidvrtype enabled
clean EQ
clean EQ
clean EQ
clean EQ
clean EQ
clean EQ
clean EQ
##### Apply #11 #####
write engine 0 30h sdn_line_det as 0 (0x00400022)
write engine 1 30h sdn_line_det as 0 (0x00400022)
write engine 0 30h sdn_max_filter_level as 0 (0x00400002)
write engine 1 30h sdn_max_filter_level as 0 (0x00400002)
write engine 0 30h sdn_min_filter_level as 0 (0x00400000)
write engine 1 30h sdn_min_filter_level as 0 (0x00400000)
write engine 0 30h spatialEn as 0 (0x00400000)
write engine 1 30h spatialEn as 0 (0x00400000)
write engine 0 2Ch tdn_var_cr as 4 (0x00004202)
write engine 1 2Ch tdn_var_cr as 4 (0x00004202)
write engine 0 2Ch tdn_var_cb as 4 (0x00004402)
write engine 1 2Ch tdn_var_cb as 4 (0x00004402)
write engine 0 2Ch tdn_var_y as 6 (0x00004406)
write engine 1 2Ch tdn_var_y as 6 (0x00004406)
write engine 0 2Ch rapid_recover as 0 (0x00004406)
write engine 1 2Ch rapid_recover as 0 (0x00004406)
write engine 0 2Ch temporalEn as 1 (0x80004406)
write engine 1 2Ch temporalEn as 1 (0x80004406)
write engine 0 30h sdn_line_det as 0 (0x00400000)
write engine 1 30h sdn_line_det as 0 (0x00400000)
write engine 0 30h sdn_max_filter_level as 0 (0x00400000)
write engine 1 30h sdn_max_filter_level as 0 (0x00400000)
write engine 0 2Ch tdn_var_cr as 4 (0x80004406)
write engine 1 2Ch tdn_var_cr as 4 (0x80004406)
write engine 0 2Ch tdn_var_cb as 4 (0x80004406)
write engine 1 2Ch tdn_var_cb as 4 (0x80004406)
write engine 0 2Ch tdn_var_y as 6 (0x80004406)
write engine 1 2Ch tdn_var_y as 6 (0x80004406)
clean EQ
write engine 0 2Ch rapid_recover as 0 (0x80004406)
write engine 1 2Ch rapid_recover as 0 (0x80004406)
uiVideoLostState:1 fmt_idx=0 width:1280 heigth:720 framerate:25
adda_watchdog_thread[1001]: chip:0 chn:1 need notify: h:720 w:1280 fps:25
adda_watchdog_thread[1001]: chip:0 chn:2 need notify: h:720 w:1280 fps:25
adda_watchdog_thread[1001]: chip:0 chn:3 need notify: h:720 w:1280 fps:25
adda_watchdog_thread[1001]: chip:1 chn:0 need notify: h:720 w:1280 fps:25
adda_watchdog_thread[1001]: chip:1 chn:1 need notify: h:720 w:1280 fps:25
adda_watchdog_thread[1001]: chip:1 chn:2 need notify: h:720 w:1280 fps:25
adda_watchdog_thread[1001]: chip:1 chn:3 need notify: h:720 w:1280 fps:25
##### Apply #12 #####
##### Apply #13 #####
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
##### Apply #14 #####
adda_watchdog_thread[1001]: chip:0 chn:0 need notify: h:720 w:1280 fps:25
##### Apply #15 #####
##### Apply #16 #####
dh9910_set_linetype: channel=0,chid=0  linetype 0
dh9910_set_linetype: channel=1,chid=0  linetype 0
dh9910_set_linetype: channel=2,chid=0  linetype 0
dh9910_set_linetype: channel=3,chid=0  linetype 0
dh9910_set_linetype: channel=0,chid=1  linetype 0
dh9910_set_linetype: channel=1,chid=1  linetype 0
dh9910_set_linetype: channel=2,chid=1  linetype 0
dh9910_set_linetype: channel=3,chid=1  linetype 0
##### Apply #17 #####
dh9910_set_audio_source:iChipId:0 iPhyChn:3 iAudioSource 1!!
##### Apply #18 #####
[favce]{chn8} force to disable deinterlace (src_interlace = 0, di_result = 0, field coding = 0)
##### Apply #19 #####
##### Apply #20 #####
##### Apply #21 #####
##### Apply #22 #####
##### Apply #23 #####
##### Apply #24 #####
##### Apply #25 #####
##### Apply #26 #####
##### Apply #27 #####
##### Apply #28 #####
##### Apply #29 #####
##### Apply #30 #####
##### Apply #31 #####
##### Apply #32 #####
##### Apply #33 #####
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
Imagesize error: -1
chn:0 eq level:0
chn:1 eq level:0
chn:2 eq level:0
chn:3 eq level:0
chn:4 eq level:0
chn:5 eq level:0
chn:6 eq level:0
chn:7 eq level:0
chn:0 eq level:0
chn:1 eq level:0
chn:5 eq level:0
chn:6 eq level:0
##### Apply #34 #####
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
##### Apply #35 #####
##### Apply #36 #####
##### Apply #37 #####
##### Apply #38 #####
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
gm8210 vol = 100
##### Apply #39 #####
##### Apply #40 #####
##### Apply #41 #####
##### Apply #42 #####
gm8210 vol = 100
gm8210 vol = 100
##### Apply #43 #####
##### Apply #44 #####
##### Apply #45 #####
##### Apply #46 #####
##### Apply #47 #####
##### Apply #48 #####
##### Apply #49 #####
##### Apply #50 #####
##### Apply #51 #####
##### Apply #52 #####
##### Apply #53 #####
##### Apply #54 #####
в каталоге Config лежит вот это
/mnt/mtd/Config # ls
input_res    output_type  standard
то есть u-boot не выводится
или может я нашел "не тот" rs232?
Re: Cброс пароля hcvr5108h-s2
Сообщение iTuneDVR » 30 май 2016, 15:59
Лог с самого начала, до разворота линукса?
Сделай
ls /mnt/mtd -la
раз тебя уже пускает в консоль!
Это действительно дахуа или...?
Фото с меню ввода пароля?
Но, если это новый дахуа, то на 2015-05-30
403160
dsbios
Сообщение dsbios » 30 май 2016, 16:50
iTuneDVR писал(а):Лог с самого начала, до разворота линукса?
до линукса - цыфра 0, пауза 5 секунд и пошло-поехало Uncompre...
iTuneDVR писал(а):Сделай
ls /mnt/mtd -la
ls /mnt/mtd -la
total 12
drwxrwxrwx    3 10000    10000         1024 Jan  1 00:00 .
drwxrwxrwx    4 10000    10000         1024 Jul  8  2015 ..
drwxrwxrwx    2 10000    10000         1024 Jan  1 00:00 Config
-rwxrwxrwx    1 root     root          4376 Jan  1 00:00 avss.info
-rwxr-xr-x    1 root     root          3263 Jan  1 00:00 gmlib.cfg
iTuneDVR писал(а):Это действительно дахуа или...?
403160
это новый дахуа.
я, еще, может не там rs232 нашел. тастером намерял иприпаял к одному, но заметил на плате надпись "rs232", но проверить - тестер угнали(
dsbios
Сообщение dsbios » 30 май 2016, 17:02
iTuneDVR писал(а):Но, если это новый дахуа, то на 2015-05-30
403160
и да, паролий подошел
спасибо большое
самому разбираться времени не особо есть
Сообщение iTuneDVR » 30 май 2016, 17:21
Как правило там TTL, но редко бывает у дахуа RS232 на плате.
Рад, что пароль подошел.
Тогда фотку с меню версии регистратора, если можно.
dsbios
Сообщение dsbios » 30 май 2016, 17:31
iTuneDVR писал(а):Как правило там TTL, но редко бывает у дахуа RS232 на плате.
Сообщение iTuneDVR » 30 май 2016, 18:14
Да, это дахуа!
Благодарствую за фото ;)
