Страница 1 из 1
Need Help For my DS-2CD2145F-IS CAM
Добавлено: 08 мар 2016, 00:26
homer51
Hi to All !
I come to you because i have good return about your master board.
Here is my problem
I need your help, i bought few week ago a new Hik on Ali, an DS-2CD2145F-IS V5.3.3 4MP, from this seller http://fr.aliexpress.com/item/2015-New- ... wVersion=1
The product is good, firmware is / was in full language.
Other after some configuation update i lost access to the cam, it crashed after only 1 month, no come back, and the only way was a hard reset by button, and use TFTP to come back my cam.
But now my cam is in chinese, firmware is 5.3.5_150925 multilanguage by origin.
I contact seller from Ali, no answer :-( really not serious, i put him 5 stars, good evaluation before, and now no answer at all.
:cry:
I'm very sad, because it was my favorite cam, do you have any plan to recover the firmware by another one or a hack to get back language ? because for now IVMS dosen't want anymore my cam.
I have a friend who has the same cam, is it possible to read firmware with TFTP and revover mine with or it's more hard than that.
Here is some information about my cam
i update cam with this firmware (same as original chinese firmware i think) witht TFTP
Re: Need Help For my DS-2CD2145F-IS CAM
Добавлено: 08 мар 2016, 00:57
So, will try with your firmware on my IPC.
Добавлено: 08 мар 2016, 08:14
homer51
Thanks ! If i can help you let me know :-)
Добавлено: 08 мар 2016, 10:47
homer51 писал(а):Thanks ! If i can help you let me know :-)
ok
Добавлено: 08 мар 2016, 23:21
homer51
Hi,
Can i change some value with an hex editor and inject firmware for test to recover language ?
Or it's dangerous for the cam ? Brick ?
Other, does the cam can works in chinese configuration with an NVR like the DS-7608NI-I2 / 8 P
Thanks for your support
Добавлено: 09 мар 2016, 00:53
homer51 писал(а):Hi,
I think you can't do anything.
homer51 писал(а):Other, does the cam can works in chinese configuration with an NVR like the DS-7608NI-I2 / 8 P
Possible via only ONVIF and inly videostream without detection and others +++ you can get at your NVR from this IPC in H264 mode.
