NPIp>XSATOodma1 ini_ver 0x11210818
ETH trim = 000024F0
speed 000003A4
Non S3
>ddr3
WT
dma ok
UNZOK!
Loader Start ...
LD_VER 03.00.06
560_DRAM1_933_4096Mb 07/11/2022 21:12:30
No card inserted
Pad driving increased
SPI NOR MID=000000EF,TYPE=00000040,SIZE=00000018=>01000000
SPI NOR
bl_load_fdt_from_flash
0x00000001
Q_read
tmp_addr 0x02000000
LdCtrl2 0x00000000
Q_read
uboot_addr 0x00400000
uboot_size 0x01200000
Euboot_addr 0x00020000
Euboot_size 0x00080000
Q_read
E:aes start
E:aes end
lzma fdt 0x00100000
shm 0x00200000
jump 0x00400000
U-Boot 2019.04-svn473874 (Jul 11 2022 - 21:12:38 +0800), Build: jenkins-AVI-CCI- Pipeline-1940
[OTP secure] : Write (Lock)
[Start Mode] : Secure
Relocation to 0x0183f000, Offset is 0x0143f000 sp at 01538fa0
nvt_shminfo_init: The fdt buffer addr: 0x0153e3c8
CONFIG_MEM_SIZE = 0x10000000
CONFIG_NVT_UIMAGE_SIZE = 0x01900000
CONFIG_NVT_ALL_IN_ONE_IMG_SIZE = 0x07800000
CONFIG_UBOOT_SDRAM_BASE = 0x00400000
CONFIG_UBOOT_SDRAM_SIZE = 0x01500000
CONFIG_LINUX_SDRAM_BASE = 0x01a00000
CONFIG_LINUX_SDRAM_SIZE = 0x01e00000
CONFIG_LINUX_SDRAM_START = 0x01f00000
Loading Environment from SPI Flash... nvt_spinor_reset: spi flash pinmux 0x0
id = 0xef 0x40 0x19 0x00 0x00
STDR256FW with page size 256 Bytes, erase size 4 KiB, total 32 MiB
nvt spinor 1-bit mode @ 48000000 Hz
nvt_detect_fw_tbin: Boot from flash or emmc
Card did not respond to voltage select!
MMC interface configure failed
Open SD fail: No SD device?
can't find corresponding entry
### CRAMFS LOAD ERROR<0> for DS42ca.dtb!
### CRAMFS LOAD ERROR<0> for DS42ca-BD010100.dtb!
### CRAMFS load complete: 16368 bytes loaded to 0x1a00000
Loading FDT file with name: DS17098.dtb
pub_misc_init_r: boot time: 564236(us)
DTS find cpu freq clock 960MHz
Set CPU clk 960MHz
pub_misc_init_r: boot time: 643026(us)
phy interface: INTERNAL MII
boot normal ...
cramfs: cramfs_uncompress error3!
### CRAMFS LOAD ERROR<ffffffff> for uImage!
### CRAMFS LOAD ERROR<ffffffff> for ramdisk.gz!
cramfsload 0x01A00000 uImage;cramfsload 0x03100000 ramdisk.gz; error
nvt_boot - To do nvt platform boot init.
Usage:
nvt_boot
This program will upgrade software.
* ATTENTION!! PLEASE READ THIS NOTICE CAREFULLY! *
* Don't reset machine,or anything that interrupt it. *
* The upgrade process must finish in 10 minutes! *
* If this program fails,machine might be unusable, *
* and you will need to reflash again. *
* If you find this too risky,power off machine now. *
Now press [u/U] key to upgrade software:u
Please upgrade by TFTP
Please input ip address of device:192.0.0.64
Please input ip address of upgrade server:192.0.0.128
Confirm?(y/n):y
Ввожу данные устройства и сервера, просит ввести заново, в чем проблема?
Моргнул свет на прошивке DS-KD8003-IME1(B)
Re: Моргнул свет на прошивке DS-KD8003-IME1(B)
Можно вместо u попробовать b и там осмотреться
Просто от моргания света блок cramfs на чтение не должен взять и повредиться.
Что касается адресов, то такое виду впервые. Обычно, чтобы ты не ввел идет попытка тянуть нечто с tftp, но возможно, что твой адрес сервера недоступен и потому такая логика. Сеть подключена?
Да я вчера зашел по “b” далее upgrade и началась прошивка по tftp, тему можно закрывать!
Видимо глюк
