DH-IPC-HFW1000sp восстановление
Re: DH-IPC-HFW1000sp восстановление
во спс, поставил память на mtest но вроде все целое.
При команде bootd он начинает грузить а потом начинеается циклическая перезагрузка вот лог
Terminal log file
Date: 28.02.2017 - 13:27:06
Зкшт Printt env
Unknown command 'Printenv' - try 'help'
> printenv
bootdelay=1
gatewayip=192.168.1.1
wifiaddr=00:12:34:56:78:91
loglevel=4
BSN=1A01B31PAU00208
HWID=IPC-HDW1100S:01:02:04:1D:0E:00:01:00:00:00:00:190:00:00:02:00:00:00:00:00:80
devalias=IPC-HFW1000S
icrtype=1
ID=1B00287PAU00188
ethaddr=4C:11:BF:A2:A5:6C
serverip=192.168.1.10
ipaddr=192.168.1.108
filesize=BE67A9
fileaddr=82000000
da=tftp 0x82000000 dhboot.bin.img;flwrite;tftp 0x82000000 dhboot-min.bin.img;flwrite;
dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite;
dk=tftp 0x82000000 kernel.img;flwrite;
du=tftp 0x82000000 user-x.squashfs.img; flwrite
dw=tftp 0x82000000 web-x.squashfs.img; flwrite
dp=tftp 0x82000000 partition-x.cramfs.img;flwrite;
dc=tftp 0x82000000 custom-x.squashfs.img; flwrite
up=tftp 0x82000000 update.img;flwrite;
tk=tftp 0x82000000 uImage;bootm;
bootcmd=sf read 0x82000000 0x180000 0x280000;bootm 0x82000000;
bootargs=mem=85M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
ver=U-Boot 2010.06-svn2134 (May 26 2014 - 16:15:03)
Environment size: 1096/262140 bytes
> bootd
Image Name: Linux-3.0.8
Data Size: 1372744 Bytes = 1.3 MiB
Entry Point: 80008000
Loading Kernel Image ...OK
partition file version 2
rootfstype squashfs root /dev/mtdblock7
cmdLine mem=85M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
Linux version 3.0.8 (@centos-68) (gcc version 4.4.1 (Hisilicon_v100(gcc4.4-290+uclibc_0.9.30.2+eabi+linuxpthread)) )
Machine: hi3518
ethaddr0=4c:11:bf:a2:a5:6c
ethaddr1=0:0:0:0:0:0
wifiAddr=0:12:34:56:78:91
lip0=192.168.1.108
lip1=0.0.0.0
id=1B00287PAU00188
U-Boot 0x40000 0x80000 0x0
hwid 0x40000 0xc0000 0x0
custom 0x20000 0x140000 0x0
product 0x20000 0x160000 0x0
Kernel 0x160000 0x180000 0x0
web 0x220000 0x2e0000 0x0
romfs 0x1a0000 0x500000 0x0
user 0x840000 0x6a0000 0x0
syslog 0x60000 0xee0000 0x0
config 0x60000 0xf40000 0x0
backup 0x60000 0xfa0000 0x0
num parts is 12.
gLogRamRes: start=0x8547e000;size=0x80000
init gLogRamRes: start=0x8547e000;size=0x80000
init gMemRelimitAddr:0x854fe000
AXI bus clock 220000000.
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 21590
Kernel command line: mem=85M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs
dh_keyboard:0
Memory: 85MB = 85MB total
Memory: 81944k/81944k available, 5096k reserved, 0K highmem
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xfe000000 ( 904 MB)
lowmem : 0xc0000000 - 0xc5500000 ( 85 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0020000 ( 96 kB)
.text : 0xc0020000 - 0xc0375000 (3412 kB)
.data : 0xc0376000 - 0xc0390c00 ( 107 kB)
.bss : 0xc0390c24 - 0xc03a53d0 ( 82 kB)
NR_IRQS:32 nr_irqs:32 32
devtmpfs: initialized
console [ttyS0] enabled
msgmni has been set to 160
Spi id table Version 1.22
reset/hold pin now is RESET
Spi(cs1):
Block:64KB
Chip:16MB
spi size: 0x16777216
chip num: 1
0x0000006a0000-0x000000ee0000 : "user"
0x000000ee0000-0x000000f40000 : "syslog"
Fixed MDIO Bus: probed
himii: probed
get phy addr:1
hub 1-0:1.0: 1 port detected
hub 2-0:1.0: 1 port detected
TCP bic registered
шVFS: Mounted root (squashfs filesystem) readonly on device 31:7.
devtmpfs: mounted
Freeing init memory: 96K
jffs2_scan_eraseblock(): Node at 0x0005862c {0x1985, 0xe002, 0x00000044) has invalid CRC 0xfffffb1d (calculated 0x98f7fb1d)
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00058630: 0x0044 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00058634: 0xfb1d instead
keyboard = 0
pa:85500000, va:c5a00000
load sys.ko for Hi3518...OK!
load viu.ko for Hi3518...OK!
ISP Mod init!
load vpss.ko ....OK!
load venc.ko for Hi3518...OK!
load group.ko for Hi3518...OK!
load chnl.ko for Hi3518...OK!
load h264e.ko for Hi3518...OK!
load jpege.ko for Hi3518...OK!
load rc.ko for Hi3518...OK!
load region.ko ....OK!
0;32;32m00:00:04|[prc] Codec init ok
pdc] HWID : IPC-HDW1100S:01:02:04:1D:0E:00:01:00:00:00:00:190:00:00:02:00:00:00:00:00:80
PDC_PRODUCT_OWNER: 0
:04|[pdc] PDC_pinInit As Usual!
DULE_SENSOR
DRAM: 256 MiB
Spi(cs1): Block:64KB Chip:16MB Name:"W25Q128B"
boot from spi
Fail to get uboot hd.
TEXT_BASE:81000000
Hisilicon ETH net controler
MAC: 4C-11-BF-A2-A5-6C
Download to address: 0x84000000
Downloading: *
Fail to get info file!
Init error!
miiphy_register: non unique device name '0:1'
Downloading: *
Machine: hi3518
lip0=192.168.1.108
lip1=0.0.0.0
id=1B00287PAU00188
num parts is 12.
dh_keyboard:0
Spi(cs1):
Block:64KB
Chip:16MB
chip num: 1
himii: probed
get phy addr:1
TCP bic registered
devtmpfs: mounted
keyboard = 0
ISP Mod init!
*******load rc.ko for Hi3518...OK!
00:04|[OSA-DRV] recordTsk Task pid=516 tid=516
Kernel: ssp initial ok!
it As Usual!
R
tarting system.
DRAM: 256 MiB
boot from spi
TEXT_BASE:81000000
Hit any key to stop autoboot: 1 0
Date: 28.02.2017 - 13:27:55
End log file
Так ничего не поменялось же!!!
Память-памятью, а флеш-флешем!!!
Так что посоветуете? при команде bootd загрузка прерывается, и не удается удалить конфиг.
Ошибся )) перепаял заведомо рабочую память, ошибка осталась.
А у вас случайно нет дампа?
Kvintek писал(а):Так что посоветуете? при команде bootd загрузка прерывается, и не удается удалить конфиг.
Неправилоьные действия приводят не к тем результатам.
Kvintek писал(а):Ошибся )) перепаял заведомо рабочую память, ошибка осталась.
Какую память перепаял?
Я лишь акцентировал внимание на этом и попросил проверить флеш на логику.
Kvintek писал(а):А у вас случайно нет дампа?
Загрузчик цел, а значит всё остальное поправимо.
В логе есть также упоминание про сенсор и перезагрузка и ...
Память естественно FLASH, пере залил прошивку #run up, изменений никаких.
Проблема в другом и ты просто не понял и не сделал то, что нужно, о чём просилось.
Я указал куда рыть, а run up делает только то, что там включено в файл и ничего более
Для меня это пока лес.
Это пока тоже
Прошу пинка в нужном направлении.
Это пока тоже
Kvintek писал(а):Прошу пинка в нужном направлении
Ты его пропустил, он выше
DULE_SENSOR
насколько понимаю то это. но вот почему то даже гугл не помог.
DULE_SENSOR
