Страница 3 из 5
Re: 3104P NVR Bricked
Добавлено: 22 фев 2016, 21:28
Restore all previous link or insert photos it as attaches.
Добавлено: 22 фев 2016, 21:31
chamek
I will reupload them
Добавлено: 22 фев 2016, 21:33
chamek
Добавлено: 22 фев 2016, 21:59
Make MB photo in good quality like in viewtopic.php?t=641#p2020
All must be easy.
But if you already brake bootload, you nothing to see via TTL.
Добавлено: 22 фев 2016, 22:10
chamek
iTuneDVR писал(а):Make MB photo in good quality like in viewtopic.php?t=641#p2020
All must be easy.
this better?
Добавлено: 22 фев 2016, 23:17
YES! :)
What on pins in inside white plastic?
Добавлено: 23 фев 2016, 00:26
What is your TTL2RS232 adapter? COM, USB?
Possible this.
(possible +5V), Gd,Rx,Tx
Testin it, but if no luck, need reflash with full image.
Добавлено: 23 фев 2016, 01:13
chamek
iTuneDVR писал(а):What is your TTL2RS232 adapter? COM, USB?
Possible this.
The cable is TTL2RS232 USB.
+5v is the square conection?
Добавлено: 23 фев 2016, 01:21
chamek писал(а):+5v is the square conection?
You have power tester at your hand?
Test all thiese pins!
Добавлено: 23 фев 2016, 01:23
chamek
ok i will try no power need or do i need to plug it on electric?
