3104P NVR Bricked
Re: 3104P NVR Bricked
Restore all previous link or insert photos it as attaches.
I will reupload them
Make MB photo in good quality like in viewtopic.php?t=641#p2020
All must be easy.
But if you already brake bootload, you nothing to see via TTL.
All must be easy.
iTuneDVR писал(а):Make MB photo in good quality like in viewtopic.php?t=641#p2020
All must be easy.
this better?
YES!
What on pins in inside white plastic?
What is your TTL2RS232 adapter? COM, USB?
Possible this.
(possible +5V), Gd,Rx,Tx
Testin it, but if no luck, need reflash with full image.
Possible this.
- 3e5fd-clip-108kb.jpg (107.92 КБ) 6812 просмотров
iTuneDVR писал(а):What is your TTL2RS232 adapter? COM, USB?
Possible this.
The cable is TTL2RS232 USB.
+5v is the square conection?
chamek писал(а):+5v is the square conection?
You have power tester at your hand?
Test all thiese pins!
ok i will try no power need or do i need to plug it on electric?
