Камера на Ti платформе.
Прошивок пока нет.
Пока стопор.
Нащупал TTL подключился
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.03.05 00:16:02 =~=~=~=~=~=~=~=~=~=~=~=
DM36x initialization passed!
TI UBL Version: 1.50
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
DONE
Jumping to entry point at 0x81080000.
U-Boot 1.3.4 (Aug 9 2013 - 00:26:09)
I2C: ready
DRAM: 128 MB
NETVIEW-1 NAND: NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (Unknown NAND 128MiB 3,3V 8-bit)
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
128 MiB
link off
Ethernet PHY: INST36X @ 0x00
Hit any key to stop autoboot: 1 0
NETVIEW IPNC:>
NETVIEW IPNC:>
NETVIEW IPNC:>help
? - alias for 'help'
askenv - get environment variables from stdin
autoscr - run script from memory
base - print or set address offset
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootp - boot image via network using BootP/TFTP protocol
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dhcp - invoke DHCP client to obtain IP/boot params
echo - echo args to console
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
help - print online help
icrc32 - checksum calculation
iloop - infinite loop on address range
imd - i2c memory display
iminfo - print header information for application image
imm - i2c memory modify (auto-incrementing)
imw - memory write (fill)
imxtract- extract a part of a multi-image
inm - memory modify (constant address)
iprobe - probe to discover valid I2C chip addresses
itest - return true/false on integer compare
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
loady - load binary file over serial line (ymodem mode)
ls - list files in a directory (default /)
md - memory display
mii - MII utility commands
mm - memory modify (auto-incrementing)
mtest - simple RAM test
nand - NAND sub-system
nboot - boot from NAND device
nfs - boot image via network using NFS protocol
ping - send ICMP ECHO_REQUEST to network host
run - run commands in an environment variable
saves - save S-Record file over serial line
sleep - delay execution for some time
tftpboot- boot image via network using TFTP protocol
NETVIEW IPNC:>
NETVIEW IPNC:>
NETVIEW IPNC:>
NETVIEW IPNC:>printenv
bootdelay=1
ethaddr=00:00:1b:00:00:11
filesize=19E2000
fileaddr=82000000
ipaddr=192.168.1.12
serverip=192.168.1.15
bootcmd=nboot 0x80700000 0 0x700000;bootm 0x80700000
bootargs=console=ttyS0,115200n8 noinitrd rw ip=192.168.1.134:192.168.1.1::::: root=/dev/mtdblock3 rw rootfstype=cramfs mem=48M eth=00:00:1b:00:00:11
ver=U-Boot 1.3.4 (Aug 9 2013 - 00:26:09)
Environment size: 434/262140 bytes
NETVIEW IPNC:>
BootMode = NAND
DONE
I2C: ready
DRAM: 128 MB
128 MiB
link off
Loading from NAND 128MiB 3,3V 8-bit, offset 0x700000
Image Name: Linux-2.6.18_pro500-davinci
Data Size: 1840416 Bytes = 1.8 MB
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Uncompressing Linux........................................................................................................................... done, booting the kernel.
Linux version 2.6.18_pro500-davinci (root@ubuntu) (gcc 版本 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Fri Jun 6 09:30:46 CST 2014
Machine: DaVinci DM368 IPNC
DaVinci DM0365 variant 0x8
PLL0: fixedrate: 24000000, commonrate: 170000000, vpssrate: 340000000
PLL0: vencrate_sd: 75555555, ddrrate: 340000000 mmcsdrate: 97142857
PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
Built 1 zonelists. Total pages: 12288
Kernel command line: console=ttyS0,115200n8 noinitrd rw ip=192.168.1.134:192.168.1.1::::: root=/dev/mtdblock3 rw rootfstype=cramfs mem=48M eth=00:00:1b:00:00:11
TI DaVinci EMAC: kernel boot params Ethernet address: 00:00:1b:00:00:11
PID hash table entries: 256 (order: 8, 1024 bytes)
Clock event device timer0_0 configured with caps set: 07
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 48MB = 48MB total
Memory: 44672KB available (3149K code, 653K data, 180K init)
Security Framework v1.0.0 initialized
Capability LSM initialized
DaVinci: 104 gpio irqs
MUX: initialized GPIO20
MUX: initialized I2C_SCL
MUX: initialized SD1_DATA1
MUX: initialized GPIO28
Generic PHY: Registered new driver
ch0 default output "COMPOSITE", mode "NTSC"
VPBE Encoder Initialized
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 2048 bind 1024)
***davinci_spi_board_init()!<3>Pin SPI1_SCLK already used for SD1_DATA1.
MUX: initialized SPI1_SDO
spi1 register ret = 0 ~~~~~~~~~~~~~~~~~~~~~
***davinci_spi_board_init_End(0)!<5>VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 3.1 (2006/08/19) Phillip Lougher
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
yaffs Jun 6 2014 09:34:05 Installing.
SGI XFS with no debug enabled
Initializing Cryptographic API
io scheduler anticipatory registered (default)
LTT : ltt-facilities init
LTT : ltt-facility-core init in kernel
DAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 sec
MUX: initialized PWM0
Pin PWM2_G87 already used for GPIO87.
MUX: initialized PWM3_G80
MUX: initialized PWM3_G81
MUX: initialized PWM3_G85
MUX: initialized PWM3_G86
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550A
serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A
RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
Davinci EMAC MII Bus: probed
MAC address is 00:00:1b:00:00:11
TI DaVinci EMAC Linux version updated 4.0
Linux video capture interface: v2.00
Trying to register davinci display video device.
layer=c05cc600,layer->video_dev=c05cc760
layer=c05cc400,layer->video_dev=c05cc560
davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
i2c /dev entries driver
nand_davinci nand_davinci.0: Using 4-bit hardware ECC
Creating 6 MTD partitions on "nand_davinci.0":
0x00000000-0x00300000 : "bootloader"
0x00300000-0x00700000 : "params"
0x00700000-0x00a00000 : "kernel"
0x00a00000-0x02a00000 : "filesystem"
0x02a00000-0x02e00000 : "data1"
0x02e00000-0x08000000 : "data2"
nand_davinci nand_davinci.0: hardware revision: 2.3
MUX: initialized SPI0_SCLK
MUX: initialized SPI0_SDO)
dm_spi1.1: davinci SPI Controller driver at 0xc3865800 (irq = 43) use_dma=0
spidev_init @@@@@@@@@@@@@@@@@@@@@@@@
spidev_probe~~~~~~~~~~~~~~~~~~~~~~
spidev_init OK: 0
rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: proc
rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: dev (254:0)
rtc_davinci_dm365 rtc_davinci_dm365.0: rtc core: registered rtc_davinci_dm365 as rtc0
rtc wait time out !!!!!
Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC).
ASoC version 0.13.1
CQ0093 Voice Codec 0.1
asoc: cq93vc <-> davinci-vcif mapping ok
ALSA device list:
#0: On-chip voice codec (cq93vc)
IPv4 over IPv4 tunneling driver
TCP bic registered
rtc_davinci_dm365 rtc_davinci_dm365.0: setting the system clock to 2000-01-01 00:00:00 (946684800)
Time: timer0_1 clocksource has been installed.
Clock event device timer0_0 configured with caps set: 08
Switched to high resolution mode on CPU 0
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, addr=192.168.1.134, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.1.134, domain=, nis-domain=(none),
bootserver=192.168.1.1, rootserver=192.168.1.1, rootpath=
VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 180K
INIT: version 2.86 booting
0
mkdir: Cannot create directory `/dev/.test': Read-only file system
Starting the hotplug events dispatcher: udevd.
Synthesizing the initial hotplug events...done.
Waiting for /dev to be fully populated...done.
0
CSL: Module install successful, device major num = 252
CSL: Module version 0.10.00, built on Jun 18 2014 14:55:05
I2C: Module install successful, device major num = 251
DMA: Module install successful, device major num = 250
DRV: Module install successful
DRV: Module built on Jun 18 2014 14:55:08
DRV: EDMACC.QUEPRI = 00000777
DRV: SYSTEM.MSTPRI0 = 00440022
DRV: SYSTEM.MSTPRI1 = 00000244
DRV: ISP.BCR = 00000002
DRV: SYSTEM.MISC = 00000399
CMEMK module: built on Dec 3 2011 at 01:26:39
Reference Linux version 2.6.18
File /mnt/workdir/diskb/ipnc_ar0331/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc4000000 of size 0x5000000
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
cmemk initialized
EDMAK module: built on Dec 3 2011 at 01:26:40
File /mnt/workdir/diskb/ipnc_ar0331/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
IRQK module: built on Dec 3 2011 at 01:26:41
File /mnt/workdir/diskb/ipnc_ar0331/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
irqk initialized
<K>dm365 adc driver successful!
yaffs: dev is 32505860 name is "mtdblock4"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.4, "mtdblock4"
yaffs_read_super: isCheckpointed 0
ln: /var/www/snap.jpg: File exists
Starting mounting local filesystems: mount none on /dev/shm type tmpfs (rw,size=5M)
none on /var/run type tmpfs (rw)
none on /tmp type tmpfs (rw,sync)
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
gPlatform = 1 ~~~~~~
Creat queue id:65538
queue id:65538
Setting up networking ...rm: unable to remove `/etc/network/run': Read-only file system
queue id:32769
Global value size:21832
MagicNum: 2593849357, MagicNumConfig: 2593849357
ReadGlobal: 0 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
queue id:65538
Creat queue id:98307
queue id:98307
Starting hotplug subsystem:
Check_device_version : DEVICE VER = 1 !!
killall: phddns_c_demo: no process killed
rm: cannot remove `/mnt/nand/AcountLevel.txt': No such file or directory
rm: cannot remove `/mnt/nand/ConnectStatus.txt': No such file or directory
time.windows.com: Unknown host
/opt/ipnc/ntpclient -s -i 10 -h time.windows.com
ntpclient return 256.
@@@@@@@@@@@@@@@@@@@@StreamType: 1, VideoCombo: 4 ~~~~~~
CPU is DM368
+++++++++++++++++g_res2When720P: 4 ~~~~~~
6666666666666666666666666666666para_mpeg4cvalue/1000==2048
++++++++++++++++++++++++++++++++++++++++++++++++pSysInfo->lan_config.nFrameRate1====0
tConfig.nVideocodecmode: 3, tConfig.nVideocodecres: 1 ~~~~~~~~~~~~~~~~~~~~~~~
CPU CurrentStatus is = 1
===========pConfig -> nVideocodecmode=3=========
./av_server.out DM368 PAL TI2A AEWB FLIPH FLIPV D1_D1 H264 2048000 CBR AUTO MJPEG 75 PORT 4567 6666 MENUOFF &
TIMEZONE DAYLIGHT DEBUG COMMAND: cp -f /usr/share/zoneinfo/Etc/GMT-8 /mnt/nand/localtime
ApproDrvInit: 7
Creat queue id:131076
queue id:131076
pci
pci [success]
AVSERVER UI: Initializing.
usb
Pinmux1: 0x4f801a
Pinmux2: 0x10da
Pinmux3: 0x635affff
Pinmux4: 0x5471d400
CLK Hz,
ARM Hz = 432000000
DDR Hz = 340000000
VPSS Hz = 340000000
IMCOP Hz = 340000000
DRV LDC: GetConfig 0005 0x0
[OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
CONFIGURING AVSERVER FOR DM368 .....
queue id:65538
------------------- 720 , 576 ------------------------
sensor mode:2;fps:30;width:736;height:576;DRV_imgsOpen
Sensor Mode Info,
Width = 936
Height = 612
fps = 30
Bin Enable = 1
Sensor Frame Timing Info,
fps = 30
t_frame (ns) = 33333334.000000
t_row (ns) = 28687.500000
t_pclk (ns) = 15.625000
W = 936
H = 612
SW = 1125
SD = 0
HB = 450
VB = 549
HBmin = 450
VBmin = 9
f_pclk = 64000000
shutterOverhead (ns) = 6656.250000
col_size = 936
row_size = 612
col_bin = 0
row_bin = 0
col_start = 632
row_start = 540
pll_M = 16
pll_N = 1
pll_DIV = 1
############reset###########
############SET REG###########
DRV_imgsSet50_60Hz is50Hz: 1 ~~~~~
TI Setting Applied
~~~~~~~ 736,576,736,576 ~~~~~~~~~~~~~~~~ 736,576,736,576 ~~~~~~~~~createPrm: width x height = 720 x 576, offsetH: 736, offsetV: 576 ~~~~~~~~~~~~~~~~~~~~
DavinciDisplay DavinciDisplay.1: Before finishing with S_FMT:
layer.pix_fmt.bytesperline = 640,
layer.pix_fmt.width = 640,
layer.pix_fmt.height = 480,
layer.pix_fmt.sizeimage =460800
FR : 0 usersDavinciDisplay DavinciDisplay.1: pixfmt->width = 640,
layer->layer_info.config.line_length= 640
registered from exsiting face album
EVM AUTO_IRIS = 0
*********** min_exp = 29 ************
ag(1250,10000), dg(1024,4096),mul(a:8.000000,d:4.000000)
degree:1, step:0.121094, g:1552
ag:1250, dg:1271 -> ag:1250, dg:1271
queue id:32769
shared memory size 4096
======================== shared memory id:262152
queue id:131076
[File: rs_rtsp.c , Func: RTSP_ThrStart , Line: 02571] :Info:
MODLE: RTSP RTSP_SvrCreate
[File: rs_rtsp.c , Func: RTSP_ThrStart , Line: 02577] :Info:
MODLE: RTSP RTSP_SvrThrStart
888888888888888888888888888888888888
[File: rs_phone.c , Func: PHONE_ThrStart , Line: 00746] :Info:
MODLE: PhonePHONE_SvrCreate
[File: rs_phone.c , Func: PHONE_ThrStart , Line: 00752] :Info:
MODLE: PhonePHONE_SvrThrStart
PHONE_SvrThrFxn
[File: rs_phone.c , Func: PHONE_SvrThrFxn , Line: 00562] :Dbg:
MODLE: PhoneRendezvous_meet .......
TI AWB PRODUCTION VERSION 1.0.0
[File: rs_rtsp_base64.c, Func: RTSP_Media_Para_SetSeqBase64, Line: 00188] :Dbg:
MODLE: RtspBase64 chn:0 pSeqBase64 = Z2QAKK2EBUViuKxUdCAqKxXFYqOhAVFYrisVHQgKisVxWKjoQFRWK4rFR0ICorFcVio6ECSFITk8nyfk/k/J8nm5s00IEkKQnJ5Pk/J/J+T5PNzZprQFoJNKkAAAB4AAAcIGBAAH0AAACMoG974XhEI1
[File: rs_rtsp_base64.c, Func: RTSP_Media_Para_SetPictBase64, Line: 00212] :Dbg:
MODLE: RtspBase64 chn:0 pPictBase64 = aO48sA==
AV irismode=1
AV irisopen=0
degree:128, step:0.121094, g:20776
ag:10000, dg:2127 -> ag:10000, dg:2127
ircutmode = 0
Night2Day = 1
ircuttime: 5, fps:25, frames:125
IrcutSwitchTime = 5
Video Lost 0
framerate1: 25 ~~~
SetFramerate1 25000
framerate2: 25 ~~~
SetFramerate2 25000
SetAudioInVolume 75 ~~~~~~@@@@@@@@@@
usb [success]
isapnp
Simple mixer control 'PGA',0
Capabilities: cvolume
Capture channels: Mono
Limits: Capture 0 - 3
Mono: Capture 2 [67%]
numid=2,iface=MIXER,name='Mono DAC Playback Volume'
; type=INTEGER,access=rw---,values=1,min=0,max=63,step=0
: values=63
SetAudioOutVolume 100 ~~~~~~@@@@@@@@@@
SystemInit success
AddSysLog: (System is running now) ~~~
Schedule manager init success
isapnp [success]
ide
queue id:0
queue id:32769
route: SIOC[ADD|DEL]RT: File exists
Onvif_server is running...
Platform: TI
Console: disable
Devname: eth0
Webservice port: 8999
ide [success]
input
input [success]
scsi
scsi [success]
done.
Starting portmap daemon: portmap
Starting internet superserver: inetd.io scheduler deadline registered
sbulla: unknown partition table
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
loop: loaded (max 8 devices)
CSLIP: code copyright 1989 Regents of the University of California
netconsole: not configured, aborting
davinci-mmc davinci-mmc.0: Supporting 4-bit mode
davinci-mmc davinci-mmc.0: Using DMA mode
killall: ntpclient: no process killed
UNABLE TO SYNC TO SNTP SERVER in 10 seconds
queue id:0
umount: /mnt/mmc: not mounted
SD Card insert 1 , isInit = 1 ~~~~~~~~~~
mount: special device /dev/mmcblk0 does not exist
mount: special device /dev/mmcblk0p1 does not exist
Error -1 fault: SOAP-ENV:Client [no subcode]
"End of file or no input: Operation interrupted or timed out (5 s recv delay) (5 s send delay)"
Detail: [no detail]
111111111111111111net_get_dns: file "/etc/resolv.conf" opened for reading error!
~~~~~~~~~~~~~~~~~~ StartNetwork ~~~~~~~~~~~~~~~~~
@@@@@@@ dns==0.0.0.0,dns==0x0
cat: /etc/resolv.conf: No such file or directory
LocalIP="192.168.0.171"
NetMask="255.255.255.0"
Gateway="192.168.0.1"
DNS="192.168.0.1"
dhcp: 0 ~~~~~~~~~~~~~~~~~~~~
111111111#########################################
111111111@@@@@@@ ip==192.168.0.171
1111111111@@@@@@@ gateway==192.168.0.1
111111111111@@@@@@@ netmask==255.255.255.0
1111111111@@@@@@@ dns==192.168.0.1
dns=192.168.0.1
device: eth0
system_server/561[CPU#0]: BUG in local_bh_enable at kernel/softirq.c:196
watch_dog.c line 46shared memory size 4096
watch_dog.c line 49shared memory id:262152
========== create /var/run/watchdog.pid succeed....
CPU is DM368
Boa check platformId: 1 ~~
set_com_config tcsetattr sucsse
open /mnt/nand/ptz_control
open /mnt/nand/ptz_time_start_file
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
[01/Jan/2000:00:00:23 +0000] boa.c:365 - unable to bind: Address already in use
INIT: Entering runlevel: 3
Netview......danale p2p service...start...udwMid=40008 40020000 40020000 40020004 40020008
Netview......danale p2p service...weblanguage=9-1, MAC=00:00:1b:02:49:b6, serialnumber=VUMG9JA49I6AHXPR52
Netview......danale p2p service...Start..., __DAID__=VUMG9JA49I6AHXPR52, maxWaitMs=0
Netview......danale p2p InnovRingBuffer_Reset
In upnpDiscover........111
In upnpDiscover........112
In upnpDiscover........101
In upnpDiscover........001
In upnpDiscover........002
In upnpDiscover........003
In upnpDiscover........004
In upnpDiscover........007
In upnpDiscover........102
In upnpDiscover........103
In upnpDiscover........104
In upnpDiscover........107
In upnpDiscover........114
In upnpDiscover........113
Sending M-SEARCH * HTTP/1.1
HOST: 239.255.255.250:1900
ST: urn:schemas-upnp-org:device:InternetGatewayDevice:1
MAN: "ssdp:discover"
MX: 3
MontaVista(R) Linux(R) Professional Edition 5.0.0 (0702774)
192.168.1.134 login: Error -1 fault: SOAP-ENV:Client [no subcode]
Detail: [no detail]
192.168.1.134 login: Sending M-SEARCH * HTTP/1.1
ST: urn:schemas-upnp-org:service:WANIPConnection:1
MX: 3
admin
Password: Error -1 fault: SOAP-ENV:Client [no subcode]
Detail: [no detail]
ST: urn:schemas-upnp-org:service:WANPPPConnection:1
MX: 3
ST: upnp:rootdevice
MX: 3
M-SEARCH Reply:
ST: upnp:rootdevice
Location: http://192.0.0.128:2869/upnphost/udhisapi.dll?content=uuid:f12f88ae-364e-45e6-9549-852cb6fda03f
found device: http://192.0.0.128:2869/upnphost/udhisapi.dll?content=uuid:f12f88ae-364e-45e6-9549-852cb6fda03f
Netview......danale p2p service started
connected
Netview......StreamDispatchThrFxn recv [16] channel[0]
>>>>>>>>>>>> P2P started <<<<<<<<<<<<
Netview......StreamDispatchThrFxn recv buffer size[48]Hello-Innov
Login incorrect
192.168.1.134 login: 192.168.1.134 login: Error -1 fault: SOAP-ENV:Client [no subcode]
Detail: [no detail]
admin
Password:
Detail: [no detail]
Login incorrect
192.168.1.134 login: admin
Detail: [no detail]
Login incorrect
Detail: [no detail]
192.168.1.134 login: root
Password:
Detail: [no detail]
Login incorrect
Detail: [no detail]
adminError -1 fault: SOAP-ENV:Client [no subcode]
Detail: [no detail]
lvjh
Detail: [no detail]
=====reboot system now (boa)!!!!!11111
BootMode = NAND
DONE
I2C: ready
DRAM: 128 MB
128 MiB
NETVIEW IPNC:>
NETVIEW IPNC:>
NETVIEW IPNC:>
NETVIEW IPNC:>
Альбом http://vk.com/album221982133_229778271
